Old 12-17-2014, 06:44 AM   #1
Hempo
Drives: Subaru BRZ
18*9,5 +23 with 265's?
Tried searching but couldn't find anyone with 23 in offset..
Anyone here got 265/35-18 to fit in the rear with the same rim specs as in the title?
Hempo is offline   Reply With Quote
Old 12-17-2014, 07:38 AM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I have that tire and wheel size with a +37 in the back. -1.7 camber. I barely fit. It's still rubs while driving too.
I mean it would "fit", but you'd have to run a pretty good amount of camber to do it.
People with that offset are stretching 225/40s on the wheels and running like -2 to -2.5 camber to fit without a bunch of rub.
TylerLieberman is offline   Reply With Quote
Old 12-17-2014, 10:13 AM   #3
Hempo
Drives: Subaru BRZ
Did you roll your fenders or are they untouched?
I'm planning coilovers and rolling the fenders with a decent (not crazy) amount of camber.. since i don't want to get new wheels or run a skinny 235-245...
Old 12-17-2014, 11:30 AM   #4
TylerLieberman
Drives: '24 GR86
They're rolled. Mildly. I don't like that crazy roll and flare bullshit on these cars. Looks dumb imo.
If you're deadset on running that wide of a tire, you're gonna need a hefty amount of camber.
I say change tire size or change wheel size. Unless you're trying to run an extreme amount of camber
Old 12-17-2014, 11:57 AM   #5
Hempo
Drives: Subaru BRZ
Alright,
My thoughts were 2.5-3 degrees of negative camber might do it.. I don't like the crazycamber look either..
Or cut the fenders and go widebody
Old 12-17-2014, 12:24 PM   #6
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Minimal -3. I'm running 245/40 on 18x 9.5 +34 with -2 camber all around and it'll barely fit without a roll... And occasionally still rub the tab.
Decimus is offline   Reply With Quote
Old 12-17-2014, 12:27 PM   #7
TylerLieberman
Drives: '24 GR86
Alright,
You're going to need like -4 at least.
My wheels barely fit and still rub a little at -1.7 and your wheels are going to poke a full inch more than mine.
The Following User Says Thank You to TylerLieberman For This Useful Post:
Hempo (12-17-2014)
Old 12-17-2014, 09:01 PM   #8
jawnthen
Drives: 2013 BRZ Limited 6AT
I think these guys are right with the camber numbers.
I have 18x9.5 +29 with a 255/35R18
Dropped 1" with -1.5 camber. It pokes out about an inch but at this height I don't rub. No fender mods either. I'll probably need to increase my camber at some point.
jawnthen is offline   Reply With Quote
Old 12-18-2014, 04:33 AM   #9
Hempo
Drives: Subaru BRZ
Thanks, i guess i'll have to run 235's...
At the moment i'm dropped 1.2" with 245's and no fender mods with sliiight rubbing in the rear..
