| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Subaru BRZ
18*9,5 +23 with 265's?
Tried searching but couldn't find anyone with 23 in offset..
Anyone here got 265/35-18 to fit in the rear with the same rim specs as in the title? |
#2 |
Drives: '24 GR86
I have that tire and wheel size with a +37 in the back. -1.7 camber. I barely fit. It's still rubs while driving too.
I mean it would "fit", but you'd have to run a pretty good amount of camber to do it. People with that offset are stretching 225/40s on the wheels and running like -2 to -2.5 camber to fit without a bunch of rub.
#3 | |
Drives: Subaru BRZ
Did you roll your fenders or are they untouched? I'm planning coilovers and rolling the fenders with a decent (not crazy) amount of camber.. since i don't want to get new wheels or run a skinny 235-245... |
#4 | |
Drives: '24 GR86
They're rolled. Mildly. I don't like that crazy roll and flare bullshit on these cars. Looks dumb imo. If you're deadset on running that wide of a tire, you're gonna need a hefty amount of camber. I say change tire size or change wheel size. Unless you're trying to run an extreme amount of camber
#5 | |
Drives: Subaru BRZ
My thoughts were 2.5-3 degrees of negative camber might do it.. I don't like the crazycamber look either.. Or cut the fenders and go widebody
#6 |
BAE
Drives: Asphalt FRS
Minimal -3. I'm running 245/40 on 18x 9.5 +34 with -2 camber all around and it'll barely fit without a roll... And occasionally still rub the tab.
#7 | |
Drives: '24 GR86
You're going to need like -4 at least. My wheels barely fit and still rub a little at -1.7 and your wheels are going to poke a full inch more than mine.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | Hempo (12-17-2014) |
#8 |
Drives: 2013 BRZ Limited 6AT
I think these guys are right with the camber numbers.
I have 18x9.5 +29 with a 255/35R18 Dropped 1" with -1.5 camber. It pokes out about an inch but at this height I don't rub. No fender mods either. I'll probably need to increase my camber at some point.
#9 | |
Drives: Subaru BRZ
At the moment i'm dropped 1.2" with 245's and no fender mods with sliiight rubbing in the rear.. |
