Old 12-16-2014, 02:24 PM   #1
Series.Ru
Drives: '15 Series.Blue
which is a better route for the front set up
I'm having a hard time choosing between running 6 1/2 + 1 components and upgrading the 3.5-4", or getting 3.5-4" + 1 components and seperately upgrading the 6.5's
Series.Ru is offline   Reply With Quote
Old 12-16-2014, 03:21 PM   #2
fika84
fika84's Avatar
Kind of depends on what you want. I personally upgraded the 3.5's to MTX Thunder35 in the dash (replacing the components with coax) and put a 10" solo baric in the trunk... The 6.5's are pretty worthless and really only cause rattling in the door, but I'm sure if you insulated them a bit better and found something that worked to replace them with it might be OK.
The MTX's give nice trebble and the sub is all the bass I could ever need.
fika84 is offline   Reply With Quote
Old 12-16-2014, 08:42 PM   #3
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I agree, it really depends on what you're going for and how much you're willing to spend. I'm upgrading everything, putting a 4" in the dash, a 6.5" in the door and tweets in custom A-pillars. I'm running them active, so that's another consideration: how you're powering them. If you provide a little more info we can help even more.
kmbkk is offline   Reply With Quote
Old 12-16-2014, 09:10 PM   #4
quality_sound
Drives: '15 BRZ Series.Blue
If you don't know how to properly tune a 3-way front stage I would HIGHLY suggest you stick to a 2-way front stage. You don't just simply throw random speakers in there and hope for the best.
quality_sound is offline   Reply With Quote
Old 12-17-2014, 08:43 AM   #5
Chimera
Drives: FRS
So I expect you're probably going to facepalm. I am running this setup on front stage using the pioneer head unit auto tuning. I think it sounds quite nice.
Infinity Reference X REF-6502ix
Infinity Reference X REF-3002cfx
Infinity Reference X REF-075tx
With crx-303 crossovers
crossover points at on the crx-303
•Woofer Frequency: 20Hz-500Hz
•Midrange Frequency: 500Hz-3.5kHz
•Tweeter Frequency: 3kHz-20kHz
At 4 ohm
at 3 ohm for infinitys thats 375 2625 and 2250
I left the tweeters inline crossover which is at 2500hz
Everything is powered at 45 w and mounted in Stock locations
Old 12-17-2014, 05:56 PM   #6
quality_sound
I wouldn't say I'm going to facepalm, but in this scenario you have three tweeters. Those tweeters are going to make the effective cone area of each speaker smaller as well as diffract the sound. Even a simpler 2-way component set like some of the entry level sets from almost any reputable manufacturer on Crutchfield would likely work better. Hell, I'd sell you my Illusion Audio components if I thought you were interested.
If you can return the Infinitys and get a true component set, I would highly recommend that you go that route. You can always upgrade to a 3-way set later wehn youre ready to truly expand your system.
The Following User Says Thank You to quality_sound For This Useful Post:
Chimera (12-17-2014)
Old 12-17-2014, 11:23 PM   #7
Chimera
Drives: FRS
Pretty much impossible to return the speakers. :'( does not a crossover help with the situation about multiple tweeters though? For instance the door has them but no highs are audible from the doors at all.
I'm not arguing that a proper set would be better, I am just curious about the multiple tweeter aspect and how a cross over influences it.
Old 12-19-2014, 02:02 PM   #8
quality_sound
It will keep you from actually playing 6 tweeters but the other issue is that you have these extra tweeters sitting in front of the mid and midbass. That will cause the sound to reflect off of the tweeters, back to the cone, and combine with the new sound. Is it a MAJOR problem? Not particularly. Just one that can be avoided. Like the smaller cone area. Will the extra cone area that the tweeter poles take up really cost you much in output? Nope. It's just not ideal.
Chimera (12-20-2014)
Anyone went the FI route? Musickmixxer90 Hawaii 7 09-18-2014 10:24 PM
Went a different route for Torque YamahaR86 Electronics | Audio | NAV | Infotainment 17 03-07-2014 11:04 AM
Fastest/most fun route to take from SF to LV? Bach415 Northern California 9 07-29-2013 04:06 PM
Need good route xanth123 Northwest 7 06-11-2013 02:19 AM
SCCA route 66 sunday Hawaiian Great Lakes 3 04-27-2013 04:08 PM
