Old 12-16-2014, 01:32 PM   #1
SquadRogue
Drives: Steel FR-S 2015
"2015" FR-S Issues
SquadRogue is offline   Reply With Quote
Old 12-16-2014, 01:40 PM   #2
You are gonna have crickets and they should not be a surprise to you. They are not an "issue" as has been stated a million times on here
Need a bit more detail for the brake pedal but from what you said it sounds normal. They don't engage right away.
I have had zero "issues" on my 14 and doubt that they slid back to early 13 initial production methods so would hope you have the same luck.
TRD-X (12-16-2014)
Old 12-16-2014, 01:40 PM   #3
AeroToy
AeroToy's Avatar
Drives: Toyota GT86 Aero 2012
Tried searching? Probably over 100 threads like this
Edit: My brake pedal has some freeplay also, but that is on my 2012 86 at 9000 miles.
-2012 GT86 Aero
AeroToy is offline   Reply With Quote
Old 12-16-2014, 02:01 PM   #4
torqdork
torqdork's Avatar
Drives: RV-7
As @Tcoat said, need more detail about the brake pedal. If you mean a "soft" initial pressure resistance that then increases with travel, it's normal. Changing pads to a more aggressive compound will eliminate it. When I run Carbotech XP-10's the pedal feels like a 911 brick throughout the full range of travel, but they're too aggressive for street use so have adjusted to the soft stock pads.
torqdork is offline   Reply With Quote
Old 12-16-2014, 02:18 PM   #5
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
The doors seem to hold more moisture than any other car I've owned. I see that some FR-S have been repaired (weather stripping) for similar issues with windows. I don't have any scratches on the windows, or squealing as was reported in earlier years though.
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
Old 12-16-2014, 02:19 PM   #6
OH shit... I just realized that OP is the "Take a picture of your tach" thread guy!
Dude you need to relax and stop trying to find things that are "wrong". I know that you may be young and this may be your first new car but you are gonna drive yourself nuts at this rate!
These cars have a bunch of idiocracies that you don't get in other cars.
The RWD set up, lack of soundproofing and very nature of the design mean you will hear and feel things that don't seem "normal".
That does not mean there is something wrong.
The Following 12 Users Say Thank You to Tcoat For This Useful Post:
1GiantTurtle (12-16-2014), AeroToy (12-16-2014), AVodka14 (12-16-2014), Caspeed (12-16-2014), driftguy (12-16-2014), eddieflyinv (12-17-2014), Error (12-17-2014), h8meh8ers (12-17-2014), Koa (12-16-2014), kodyo (12-16-2014), PBlack09 (12-16-2014), swarb (12-16-2014)
Old 12-16-2014, 02:21 PM   #7
Ya, the curved, frameless window does hold moisture but I had the same thing in a couple of cars with the same set up. No real way to avoid it.
Old 12-16-2014, 02:22 PM   #8
Tromatic
http://www.summitracing.com/parts/klz-kl-107/overview/
Or E85.
OP is off to a strong start.
Tromatic is offline   Reply With Quote
Old 12-16-2014, 02:24 PM   #9
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
did you have the dealer swap/look at the muffler bearings?
My dealer near me is working on getting a TSB going, but it looks like this might be the cause of the crickets...they're waiting to see long term(1 month) results on the 6 cars they worked on before going to corporate.
The Following 3 Users Say Thank You to continuecrushing For This Useful Post:
Koa (12-16-2014), Tcoat (12-16-2014), Ultramaroon (12-16-2014)
Old 12-16-2014, 02:27 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The Following User Says Thank You to mav1178 For This Useful Post:
roddy (12-16-2014)
Old 12-16-2014, 02:28 PM   #11
Defuser
Remember
Defuser's Avatar
I never had the issue with my G35 coupe, but that may be due to the fact that my "two-car garage" (which in reality means one-car garage) is occupied by my wife's car these days.
So my car gets all the dew and rain.
Old 12-16-2014, 02:33 PM   #12
SquadRogue
trollolol
Old 12-16-2014, 02:39 PM   #13
AeroToy
AeroToy's Avatar
Originally Posted by SquadRogue View Post
I've been driving myself insane due to the 118 Miles on it for God knows what happened in those test drives to make me not have a car last long enough due to horrible break-ins possibly. Which wants me to take extra care and precautions in case anything in the car happens I want to repair it right away. I'm almost done reading the manual and after that the 118 Miles will be a scar in my heart for the rest of the time being. I know people say don't worry about it, but how? What if somebody redlined it on the test drives which is really bad for break-ins. Last time I'm buying a new car especially an FR-S with more than 20miles on it. Somebody mentioned about the car being in safe-mode which is what I'm going to read or try to find in the manual if I find it. And make sure my car isn't in safe-mode at all. Stupid dealer also put 87 gas in my car.
So frustrated.
None of the sounds you are hearing comes from someone redlining the car, nor the slack on your pedal.
If you are thinking like this you WILL go mad.
But then again, thats why we have warranty. AND Shrinks
-2012 GT86 Aero
Old 12-16-2014, 02:43 PM   #14
So frustrated. Too much of a perfectionist and an anxious person about the small details.
There is not much they could do to hurt it at break in. There is even a school of thought that feels the harder the break in the better for the engine!
The 87 will do no harm at all. Car just won't run as well as it could but will completely recover.
If you are in "safe mode" your dash would be lit up like a Christmas tree. So if the lights are not on you are ok.
You are totally imagining things and I am starting to wonder if some counseling may not be in order (NOT a joke).
Just get the regular services done and if you have a real problem take it in and get it fixed!!!!!!
2015 Series.Blue Engine "Chirp"and 2nd Gear Grind s30series Issues | Warranty | Recalls / TSB 33 09-07-2014 01:26 AM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
