Old 12-16-2014, 08:35 AM   #1
2014 Pioneer Touchscreen GPS Antenna placement
For those of you with the 2014 AHA Pioneer radio, can any of you tell me where the GPS antenna is mounted by the factory or dealer?
The instructions that came with the GPS unit (bought it through a eBay vendor for $399) say to mount the GPS antenna to basically any spot "under" the dash, but I wanted to see if anyone know where the OEM location was. It definitely does not come with a long enough lead to go the roof, so I'm thinking it must be on the top of the dash somewhere. The antenna is about a 1 inch square black piece. If it works inside the dash that's all good, but GPS is line of sight so I would be surprised it works well there.
Old 12-22-2014, 10:30 AM   #2
Just to finish this off, it does go under the dash.
It comes with a self-stick metal plate. I placed the plate under the dash to the right of the radio and as far towards the firewall as I could reach so it was under the windshield. You then attach the magnetic antenna to the plate.
It works great. I easily pick up 9 to 10 satellites or more in that position, way more than you need for an accurate fix.
2014 Bespoke with navigation FR-S Scion plug and play indash antenna pioneer bundle FRS-HHH Audio/Visual, Electronics, Infotainment, NAV 26 04-19-2015 11:22 AM
2013 Scion FRS Pioneer HU (Touchscreen) styl3z Canada Classifieds 2 11-08-2014 10:05 AM
FS: 2014 Stock FR-S Pioneer BeSpoke Touchscreen Headunit Mykolrobinson Audio/Visual, Electronics, Infotainment, NAV 11 10-08-2014 06:35 PM
SiriusXm Antenna placement mbh1101 Electronics | Audio | NAV | Infotainment 11 04-07-2014 03:06 AM
Scion FRS 2014 Pioneer Touchscreen Headunit Question JohnAyySays Electronics | Audio | NAV | Infotainment 2 08-20-2013 04:34 PM
