Old 12-14-2014, 01:20 PM   #1
liajet24
Drives: Argento FRS
Template for OEM Armrest?
Does anyone have the paper template that comes with the OEM armrest? If so, could you please scan me a copy?
liajet24 is offline   Reply With Quote
Old 12-14-2014, 05:25 PM   #2
kodyo
Drives: Scion FR-S
Seriously, don't use it. I used it and the holes were WAY off. Mainly because once you cut it out it's very difficult to align with the center and drill the holes in the correct spots (paper isn't rigid enough). My holes were drilled way off and I had to use rubber grommets to try and cover up the sloppy holes that could be seen from the passenger seat.
I recommend the following:
1) Remove the padded top cover from the bottom hinge.
2) Cut off the two alignment posts from the bottom hinge.
3) Align and tape the bottom hinge where you want it, then drill two holes for two of the attachment screws provided (choose two that are 180 degrees apart).
4) Install two of the attachment screws and then drill the remaining holes, install remaining attachment screws.
Here is the link to the template, but heed my warning.
http://www.ft86club.com/forums/showp...8&postcount=28
http://www.ft86club.com/forums/showp...2&postcount=29
kodyo is offline   Reply With Quote
Old 05-23-2022, 05:58 PM   #3
sgtcarrot
Drives: Scion FR-S 2015 Blue and stock
Thanks, appreciate the heads up!
sgtcarrot is offline   Reply With Quote
WTB: OEM armrest or Sutty's custom armrest J.C. Want-To-Buy Requests 0 10-20-2014 06:07 PM
OEM BRZ Limited Spoiler Template: nataku Cosmetic Modification (Interior/Exterior/Lighting) 15 04-20-2013 10:32 PM
Clear Bra Template Fit? Techfl3x Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 01-10-2013 02:00 PM
Subaru BRZ Photoshop Template mezdup BRZ Photos, Videos, Wallpapers, Gallery Forum 4 09-06-2012 01:23 PM
