CANADA Canada
Old 12-13-2014, 02:32 PM   #1
daftpunk
daftpunk's Avatar
Drives: 2013 Scion FRS
Snow scraping the undercarriage
So after the massive snowfall a few days ago, I found myself out doing more work than the plows, to and from work. The snow was often higher than my clearance and I could hear the undercarriage dragging through it. Went to check the undercarriage last night and I noticed that the paint on the lower edges (behind the front wheels) had been rubbed off by the dragging.
My concern is that driving through more snow will worsen this and eventually rub through to the metal. I was just wondering if anybody has had the same issue, and what you did to remedy it.
Im thinking maybe cleaning up the spots and hitting it with some Bedliner. Jdm underbody panels would've prevented this as well.
2013 Firestorm Scion FRS
2005 Civic SI Sedan- Sold
2004 Impreza WRX - Sold
1992 Civic Hatchback - Parted, RIP
daftpunk is offline   Reply With Quote
Old 12-13-2014, 02:39 PM   #2
Jegan_V
Drives: 2023 Subaru BRZ
I was worried about that especially with this car being lower than anything I've owned before and thus did get the underbody panels. I don't know why it didn't come from the dealer with those especially when the coverage they provide is superior to the ones the cars actually came with.
Jegan_V is offline   Reply With Quote
Old 12-13-2014, 03:02 PM   #3
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Oh shit...
I should probably check mine too. The snow in my subdivision was higher than the bottom of my front bumper. I was literally plowing my way out. I actually can't believe I even made it out to be honest, but yeah I heard a lot of these sounds too and now you have me worried.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 12-13-2014, 04:03 PM   #4
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Snow will will not rub through. Unless it's more a solid form of snow/ice mixture. That's why I would put on JDM underpanels.
AVodka14 is offline   Reply With Quote
Old 12-13-2014, 04:41 PM   #5
daftpunk
daftpunk's Avatar
I didn't mean THROUGH the metal lol! But through the primer you see there, to the metal which would cause corrosion issues. Im not surprised that it had rubbed through the paint... On the underside it's little more than a light misting. I'm thinking something like Bedliner or rocker guard would withstand the snow better than the tar undercoat and paint.
Old 12-14-2014, 08:11 PM   #6
wparsons
wparsons's Avatar
JDM underpanels will also trap salt, which could lead to under body rot much faster. That's probably the reason north american markets didn't get the under panels.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
AVodka14 (12-14-2014)
Old 12-14-2014, 08:40 PM   #7
daftpunk
daftpunk's Avatar
So just to follow up, today I ended up just wiping down the area with degreaser and alcohol, then reapplied a layer of rubberized rocker guard as a sacrificial skid plate. Might not have been a good idea to have done it in this wet weather but I am expecting it to rub off again after the next crazy snowfall. We'll see how it goes.
Old 12-16-2014, 05:16 PM   #8
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
The Aozora Edition here gets them. In Japan only the top trim gets them along with the rear spoiler together as an Aero Package.
On another note my BRZ front bumper traps leaves, maybe they don't have stray leaves on the roads of Japan.
krayzie is offline   Reply With Quote
Old 12-16-2014, 07:14 PM   #9
VirUzxZ
Drives: Black on Black on Black
I've been plowing roads for... this would make it my 3rd year. So after 2 years of "plowing" and standard underpanels I saw nothing out of the ordinary for the underside. the reason I know theres not much going on down there is I picked up a set up jdm underpanels from Alphamotersports and installed them myself before the powder hit.
2013 Daily driver, winter driven btw...
VirUzxZ is offline   Reply With Quote
Old 12-16-2014, 08:33 PM   #10
HMMMMM Are you sure those areas were originally painted? The edges look like overspray and the lines are all really straight for wear. That coating is tough to get off and I don't see how some snow (no matter how deep) would do that neat a job in just one day.
Too dark to check mine but it is lowered and I have driven through a pile of snow already this year.
Old 12-17-2014, 03:25 AM   #11
daftpunk
daftpunk's Avatar
Yep! for sure there was paint that rubbed off with the abrasion along with some of the tar undercoat, but I'm not surprised - the paint underneath is just a light misting. Some of it even came off onto the cloth I used to wipe the area before I reapplied the undercoat! I was just worried that additional abrasion would wear the area down to bare metal, but from what I can tell, the protective coating on the metal there is pretty strong, and has not been compromised at all.
The Following User Says Thank You to daftpunk For This Useful Post:
Tcoat (12-17-2014)
Old 12-17-2014, 06:18 AM   #12
Thanks! Good to know. Will certainly check mine now.
Old 12-19-2014, 07:18 AM   #13
wparsons
wparsons's Avatar
Go look how much salt Japan uses in the winter vs here...
Leaves getting trapped won't rot out the underbody, salt will.
Search online for info on ~2005 altimas rotting out at the front seat mounts. Didn't happen in Japan, only in North America.
flickr
Old 12-19-2014, 01:02 PM   #14
krayzie
Drive From Home
krayzie's Avatar
Yup my friend's 2006 Maxima while living in Montreal developed a big rust hole below the front passenger seat which needed patch work.
My old Golf GTI came with plastic runners for aero at the bottom (found out when changing the fuel filter), drove the piss out of it and no issues after 6 winters. Same thing with my friend's Porsche. But I do wash my car upto 3 times a week.
Clutch scraping noise 8 six Scion FR-S / Toyota 86 GT86 General Forum 31 01-05-2015 02:39 PM
Undercarriage aero panels: Not on US BRZ? YankBoffin BRZ First-Gen (2012+) — General Topics 122 01-03-2015 10:56 PM
Solution for Clamp Scraping? DemonRawr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-08-2014 12:54 AM
Lowered on coils- scraping Dispect Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-04-2013 04:41 PM
brz winter undercarriage rust? brzadrian Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 03-11-2013 05:01 PM
