Old 12-08-2014, 07:37 PM   #1
EpidemicFRS
Drives: Asphalt frs
Valenti tail light problem
So I bought some valenti lights and having an issue with one. The driver side blinks really fast making the front turn signal and even in my gauge cluster blink fast. The problem looks like when the bulb is out and it has that blinking issue, I even tried switching sides just to see and it still has the same issue and it makes whatever side it's installed blink fast. The other one works perfectly fine. Is there a step im missing? Or is it just a defective product? Also everything lights up correctly. Just when the turn signal is the issue
EpidemicFRS is offline   Reply With Quote
Old 12-13-2014, 01:47 AM   #2
Poodles
Drives: 2015 Series.Blue
Defective as they come with load resistors installed to prevent this (it's the long skinny box on the back of the light)
Valenti tail light signal light issue djdnz Cosmetic Modification (Interior/Exterior/Lighting) 70 12-03-2017 12:49 AM
Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 nigel-jdmparts Exterior Parts - Lighting 14 06-23-2015 06:32 AM
Flasher problem after Valenti tail light install! czechm8 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-27-2014 12:00 AM
Valenti Tail light on GBS alpine Cosmetic Modification (Interior/Exterior/Lighting) 0 01-24-2014 10:16 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
