Old 12-06-2014, 05:53 PM   #1
bren5279
Drives: series.blurrr
DIY Viper 5204 Remote Start
Ok this is kind of a work in progress and will take a couple days to make so be patient.
Going to post the info then take pics as I go.
So here goes!
Also, if you see any wiring errors please let me know!
Ok so here are the wiring colors I have found so far. I know the colors and pin codes are for the BRZ but I believe the FRS has the same.
Quick notes: Flex relay is basically a relay built into the remote start to be used for whatever needed.
bren5279 is offline   Reply With Quote
Old 12-06-2014, 05:53 PM   #2
bren5279
Immobilizer:
So if you have a prox key version (push button start version) You will need a 1101T Universal proximity key module. Here is the wiring for it.
If you dont have a smart key version, Im not 100% sure on it but it lists the DEI 556UW immobilizer bypass unit, so Im guessing thats the one to use if you dont use the
Old 12-06-2014, 05:53 PM   #3
bren5279
The BRZ has two ignition wires, and two starter wires. Since the RS only has 1 of each, you will need to use the built in Flex relay, and a second additional relay to power the second starter and ignition. Below is a wiring diagram of how to do this using a single relay and the built in Flex relay.
Name:  Screen Shot 2014-12-10 at 10.45.25 AM.png
Old 12-06-2014, 05:53 PM   #4
bren5279
reserved 3
As several people have mentioned, the locks are apparently positive, below is a wiring diagram to make an inverter for the remote start with two relays, You can supposedly buy ones online too but I opted for this.
Old 12-06-2014, 05:54 PM   #5
bren5279
Reserved 4
PROGRAMMING Notes:
Program Flex relay as starter 2
Remote Start Anyone? arleewa BRZ First-Gen (2012+) — General Topics 43 08-20-2014 02:43 PM
Shop to install Viper alarm/start? l0aded Southern California 0 05-04-2014 06:57 PM
Montreal anyone for viper smart start and security :)? Mikeez CANADA 0 02-09-2014 03:18 AM
Viper 4203V Remote Start smellslikecurry Audio/Visual, Electronics, Infotainment, NAV 6 01-25-2014 12:05 PM
Viper Smart Start + Security Mikeez Electronics | Audio | NAV | Infotainment 0 01-23-2014 09:43 PM
