Old 12-05-2014, 09:07 PM   #1
JayBoii
Drives: 2015 Halo FRS
Loud Dual Catback Exhaust?
Was looking into getting a new catback exhaust as of right now and what i am looking for is a LOUD dual exhaust that has a deep tone to it and if possible one that has a rumble tone to it. I was set into buying the greddy evo3 dual catback but found out they were discontinued. No price range as of right now just need options and ill decide from there.
JayBoii is offline   Reply With Quote
Old 12-05-2014, 11:21 PM   #2
king83c10
king83c10's Avatar
Drives: 2013 FRS
Invida N1 is loud and also has a deep tone but if you want that signature Subaru rumble you will need uel headers.
king83c10 is offline   Reply With Quote
Old 12-05-2014, 11:41 PM   #3
JayBoii
On a scale of 1-10 how loud would you rate them with just the catback itself? Sorry for the noob question but i heard after the break in of the exhaust it'll go quieter?
Old 12-06-2014, 12:03 AM   #4
king83c10
king83c10's Avatar
Drives: 2013 FRS
Probably an 8, actually it should get slightly louder overtime due to the packing in the resonator and mufflers burning out. Most likely the reason the exhaust seems quieter overtime is due to you getting use to the noise. If you type frs invidia n1 in on YouTube you can get an idea of what it will sound like, but videos don't really do the N1 justice.
2013 Scion FRS::Revworks uel header::Motiv front pipe::Motiv over pipe::Invidia N1::Perrin CAI::Eibach prokit::Enkie Raijin wheels::30% tint::OFT stg2uel::TWM performance M1 Abrams shift knob::Winjet black headlights::8000k OLM HID Kit::Muteki SR48 Lug Nuts
Old 12-06-2014, 12:29 AM   #5
JayBoii
Seen some videos of it and i like it! Now i was jus looking more into the catback and found some videos of the invidia n1 catback with a catless front pipe, now the question i have is what are the pros and cons of a catless front pipe that is resonated and non resonated. I see the non resonated is cheaper and heard its somewhat louder?
Old 12-06-2014, 12:31 AM   #6
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Why do you want to be loud?
Just straight pipe it if you want max loud.
Old 12-06-2014, 12:42 AM   #7
JayBoii
Were all different and its all about preference. Also i dont want to straight pipe my frs for my own reasons.
Old 12-06-2014, 12:43 AM   #8
king83c10
king83c10's Avatar
Drives: 2013 FRS
Resonators help reduce rasp and other sounds you don't want to hear. If you remove the secondary cat there is a chance you may get some rasp. I removed my primary cat in the header but bought the motiv high flow catted front pipe, I don't have any rasp but it seems that some cars with a similar set up get some rasp. If you go ahead and replace your front pipe, you should make sure to spray all the exhaust bolts with pb blaster especially the bolts that attach the front pipe to the overpipe, I had one of those bolts break off.
Old 12-06-2014, 12:53 AM   #9
JayBoii
Resonators help reduce rasp and other sounds you don't want to hear. If you remove the secondary cat there is a chance you may get some rasp. I removed my primary cat in the header but bought the motiv high flow catted front pipe, I don't have any rasp but it seems that some cars with a similar set ups get some rasp. If you go ahead and replace your front pipe, you should make sure to spray all the exhaust bolts with pb blaster especially the bolts that attach the front pipe to the overpipe, I had one of those bolts break off.
Alright man! Love the sound of the catback just debating if i should get the invidia catless non resonated front pipe with it. Looks like i gotta do more research!
Old 12-06-2014, 01:06 AM   #10
艾洛
艾洛's Avatar
Drives: Raven
An M7 T-Titan is pretty awesome, it's loud and raspy on start but once it warms up you get a deep tone without drone. You let it go above 4000 and it screams.
@Power_out!
[ame]http://youtu.be/e5zCiiyO51s[/ame]
艾洛 is offline   Reply With Quote
Old 12-06-2014, 01:15 AM   #11
JayBoii
@Power_out!
wow that sounds nice is that just the catback? how much would this be?
Old 12-06-2014, 04:04 AM   #12
艾洛
艾洛's Avatar
Drives: Raven
Yes, and it's around $1600 the last I checked. Higher up in the $$$ range but it is music to the ears!
Old 12-06-2014, 04:23 AM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
New entry-level MXP exhaust (not the blue burnt-tip ones you see).
Loud.
And affordable.
I have it on my car, and will be looking to sell it after the New Year (under $500). Sound clips and pictures to follow from me.
In mean time, here's what was put up by Mackin folks..
[ame]http://youtu.be/1b3X_FESmB0[/ame]
-alex
Old 12-06-2014, 04:55 AM   #14
JayBoii
Does anyone know if you need a tune with a invidia catless non resonated front pipe? is this considered a test pipe? thanks
perrin catback resonated - loud enough or too loud? theflathead Engine, Exhaust, Transmission 33 01-22-2018 05:46 PM
Dezod Motorsports dual catback exhaust TheBatman Engine, Exhaust, Transmission 108 12-30-2016 03:55 PM
FOR SALE: Catback STOCK FRS/BRZ dual tip exhaust Celigts Southern California 10 07-01-2015 04:47 PM
FOR SALE: Catback STOCK FRS/BRZ dual tip exhaust Celigts Engine, Exhaust, Bolt-Ons 1 08-15-2014 11:58 AM
j2 used dual exhaust catback 256brz2013 Engine, Exhaust, Bolt-Ons 5 07-27-2013 05:40 PM
