Old 12-02-2014, 06:37 PM   #1
whip
Drives: 2014 FRS MT
Demon eyes question
I will be retrofitting a set of demon eyes in my frs headlights but have concerns about the heat build up inside the projector and bulb life. I have read that LEDs will burn out quickly due to the increased heat. I have seen YouTube videos where people use ccfl rings inside their projectors. Would one of those hold up to the heat better? What size ring would fit inside the projector?
whip is offline   Reply With Quote
Old 12-02-2014, 07:05 PM   #2
swarb
check out bimmer forums for info and it seems like ddm is the popular retailer.
Old 12-02-2014, 08:29 PM   #3
whip
Drives: 2014 FRS MT
Thanks for the reply and I will read up over there.
Just to clarify, I'm looking at placing these rings/lights INSIDE my projector to make the lens glow, I'm not going for the ring outside of the projector angel eyes.
Old 12-02-2014, 09:47 PM   #4
Poodles
Drives: 2015 Series.Blue
The demon eyes won't be on when the headlights are on, so it's not really an issue. Placement should be in front of the shield anyway so they're protected a bit.
DDM is garbage and always has been... Always makes me laugh when people put $50 HIDs on their $50K cars/trucks. Good halogen setups are that much ffs...
Old 12-03-2014, 12:44 AM   #5
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
My r fine and have been with hids for about 20k miles
drambo136 is offline   Reply With Quote
Old 12-04-2014, 10:48 AM   #6
whip
Drives: 2014 FRS MT
do you use leds? if so, what kind of bulb?
I hope i'm not over thinking this project, I just really dont want to have to take off my bumper and bake open my headlights every time a bulb burns out.
Old 12-04-2014, 11:21 AM   #7
drambo136
drambo136's Avatar
Yes I got a pair of 168 sockets and led bulbs from autozone. You can also use 194 bulbs and sockets they r interchangeable. The only thing I'd suggest is to get better quality bulbs than autozone( maybe diode dynamics) and also make sure ur supplying the leds with the correct amount of voltage. I powered mine with just the battery and I am expect them to burn out. Given its only a 2 voltage increase I maybe take awhile but it will still be faster than normal.
If u have any other questions let me know.
Its not so much a hard thing to do but its just a pain in the ass
Old 12-04-2014, 11:23 AM   #8
drambo136
drambo136's Avatar
Ohhh one more thing. Be careful where u mount ur sockets. I went to close to the projector housing and had to cut a little tab
Demon Eyes retrosmiths DIY (Do-It-Yourself) Guides 19 09-04-2013 05:07 PM
Demon Eyes retrosmiths Cosmetic Modification (Interior/Exterior/Lighting) 16 05-20-2013 12:55 AM
Headlight lens question (demon eyes) WolfsFang Cosmetic Modification (Interior/Exterior/Lighting) 19 09-30-2012 02:58 PM
