| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Customizable features
Just got my BRZ. Very satisfied, but there are a few things that could be better. Primarily I would love it if all the damn buzzers were set to 0 volume or turned off completely.
In section 6-2 of the manual it states that all of these features can be changed but only at the dealer. Does anyone have any experience with this? |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Which buzzers do you want turned off?
The shift light beep can be turned off by you. I'm not sure about seatbelt chime, but you can try putting the car in ON and then engaging and removing the driver's seatbelt buckle 20 times in 30 seconds. That's how to disable it for Subarus. Anything else, I'm not sure on. You could find the buzzer and put some tape over the speaker hole. That will muffle most chimes. |
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
I agree, I know my dodge has features I've had to take it to the dealership for to enable/disable. Was hoping there would be some crazy key sequences to do that on the BRZ.
Can't recall what I read in the manual yet, but the one thing I don't want is the alarm activation chirp. Those drive me crazy! |
Na-Nu Na-Nu
Drives: 2013 Subaru BRZ Limited (GBS)
Am I too suspicious, or is this a gullible test?
LIMITED 6MT Galaxy Blue Silica
Corner Junkie
People are too suspicious these days.
http://www.iwsti.com/forums/3218023-post2547.html http://www.subaruoutback.org/forums/...elt-chime.html http://forums.nasioc.com/forums/show...77&postcount=3 And I've done it myself. It's the official procedure to disable the chime. After doing this, it will beep a few times and then stop. Again, I have NO idea if this will work with the BRZ/FR-S. I haven't tested it, and considering how much of the body electronics come from Toyota, I'm not too confident that it will work. But since it's so easy to do, I figure it won't hurt to try. |
Drives: 2023 Toyota GR 86 Cup
The customizable features listed in Section 6-2 have to be done at the dealer via the SSM3
Thanks Opie.
Drives: WRB BRZ 6AT
diabling seatbelt chime
has anybody confirmed the trick to disable seatbelt chime?
I've tried it.... turn ignition to ON position, insert/remove belt clip 20 times in 30 sec, turn off car, no dice.... still beeps |
I unplugged the wire under the seat.
#10 |
Drives: 2013 Subaru SWP BRZ Limited 6AT
Press the start/stop button!
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#11 |
Drives: DGM BRZ
That method worked on my 2010 Legacy... haven't tried BRZ yet
#12 |
Corner Junkie
Yeah, I tried it on my BRZ and it didn't work either. I wasn't confident that it would, but figured it was worth the try.
#13 |
Drives: WRB BRZ 6AT
#14 |
Of course, first pull this cover off, I suspect all models will have it:
![]() Pull it toward the front of the car to pop it off, be careful so you don't bend the crap out of it. Unplug and wrap up the middle plug: ![]() Irritant eliminated!
| Standard Features now posted on Scion.com | Linseal | Scion FR-S / Toyota 86 GT86 General Forum | 40 | 09-15-2012 03:02 PM |
| Ideas of making FR-S with BRZ model features | ngabdala | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 04-29-2012 11:19 PM |
| FR-S Standard Features | zAnSh1n | Scion FR-S / Toyota 86 GT86 General Forum | 182 | 04-04-2012 04:23 PM |
| Throttle Blip, and other features? | ashtray | BRZ First-Gen (2012+) — General Topics | 39 | 03-07-2012 10:52 AM |
