Old 06-05-2012, 11:26 AM   #1
Cack
Customizable features
Just got my BRZ. Very satisfied, but there are a few things that could be better. Primarily I would love it if all the damn buzzers were set to 0 volume or turned off completely.
In section 6-2 of the manual it states that all of these features can be changed but only at the dealer. Does anyone have any experience with this?
Cack is offline   Reply With Quote
Old 06-05-2012, 11:52 AM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Which buzzers do you want turned off?
The shift light beep can be turned off by you. I'm not sure about seatbelt chime, but you can try putting the car in ON and then engaging and removing the driver's seatbelt buckle 20 times in 30 seconds. That's how to disable it for Subarus.
Anything else, I'm not sure on. You could find the buzzer and put some tape over the speaker hole. That will muffle most chimes.
Old 06-05-2012, 02:40 PM   #3
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
I agree, I know my dodge has features I've had to take it to the dealership for to enable/disable. Was hoping there would be some crazy key sequences to do that on the BRZ.
Can't recall what I read in the manual yet, but the one thing I don't want is the alarm activation chirp. Those drive me crazy!
michaelahess is offline   Reply With Quote
Old 06-05-2012, 03:44 PM   #4
dorkymork
Na-Nu Na-Nu
dorkymork's Avatar
Drives: 2013 Subaru BRZ Limited (GBS)
Am I too suspicious, or is this a gullible test?
LIMITED 6MT Galaxy Blue Silica
dorkymork is offline   Reply With Quote
The Following User Says Thank You to dorkymork For This Useful Post:
Guff (09-27-2012)
Old 06-05-2012, 05:08 PM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
People are too suspicious these days.
http://www.iwsti.com/forums/3218023-post2547.html
http://www.subaruoutback.org/forums/...elt-chime.html
http://forums.nasioc.com/forums/show...77&postcount=3
And I've done it myself. It's the official procedure to disable the chime. After doing this, it will beep a few times and then stop.
Again, I have NO idea if this will work with the BRZ/FR-S. I haven't tested it, and considering how much of the body electronics come from Toyota, I'm not too confident that it will work. But since it's so easy to do, I figure it won't hurt to try.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
dorkymork (06-05-2012), Guff (09-27-2012)
Old 06-05-2012, 05:15 PM   #6
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
The customizable features listed in Section 6-2 have to be done at the dealer via the SSM3
Opie is offline   Reply With Quote
Old 06-05-2012, 05:51 PM   #7
Cack
Thanks Opie.
Old 09-27-2012, 01:40 PM   #8
jflBRZ
jflBRZ's Avatar
Drives: WRB BRZ 6AT
diabling seatbelt chime
has anybody confirmed the trick to disable seatbelt chime?
I've tried it.... turn ignition to ON position, insert/remove belt clip 20 times in 30 sec, turn off car, no dice.... still beeps
jflBRZ is offline   Reply With Quote
Old 09-27-2012, 02:28 PM   #9
michaelahess
I unplugged the wire under the seat.
Old 09-27-2012, 02:42 PM   #10
zoomzoomers
zoomzoomers's Avatar
Press the start/stop button!
Old 09-27-2012, 02:45 PM   #11
azngolfur
azngolfur's Avatar
Drives: DGM BRZ
That method worked on my 2010 Legacy... haven't tried BRZ yet
azngolfur is offline   Reply With Quote
Old 09-27-2012, 03:16 PM   #12
Draco-REX
Corner Junkie
Draco-REX's Avatar
Yeah, I tried it on my BRZ and it didn't work either. I wasn't confident that it would, but figured it was worth the try.
Old 09-28-2012, 03:08 AM   #13
jflBRZ
jflBRZ's Avatar
Drives: WRB BRZ 6AT
got a pic?
Old 09-28-2012, 12:22 PM   #14
michaelahess
got a pic?
Of course, first pull this cover off, I suspect all models will have it:
Pull it toward the front of the car to pop it off, be careful so you don't bend the crap out of it.
Unplug and wrap up the middle plug:
Irritant eliminated!
The Following User Says Thank You to michaelahess For This Useful Post:
jflBRZ (09-28-2012)
Standard Features now posted on Scion.com Linseal Scion FR-S / Toyota 86 GT86 General Forum 40 09-15-2012 04:02 PM
Ideas of making FR-S with BRZ model features ngabdala Scion FR-S / Toyota 86 GT86 General Forum 23 04-30-2012 12:19 AM
FR-S Standard Features zAnSh1n Scion FR-S / Toyota 86 GT86 General Forum 182 04-04-2012 05:23 PM
Throttle Blip, and other features? ashtray BRZ First-Gen (2012+) — General Topics 39 03-07-2012 11:52 AM
