Old 11-29-2014, 09:34 PM   #1
frslee
Just drive it
Drives: 13' FR-S
Question prior fuel pump noise warranty repair
Hi,
I finally made an appointment at dealer for fuel pump replacement. My question is, do they reset the ecu after the repair? Since I'm on Openflash Tablet tune, I was wondering if I have to turn it back to stock tune before bringing it in.
frslee is offline   Reply With Quote
Old 11-29-2014, 09:43 PM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
When I took mine in I flashed it back to stock, just to be safe. I honestly don't think they do anything to the ECU.
Bobblehead is offline   Reply With Quote
Old 11-29-2014, 10:15 PM   #3
Koa
without a doubt, flash back. Way too easy to maintain a record these days. Best case scenario, they don't even pry into the ecu. Worst case scenario they run a scan, find out the tune has been altered with, and documented. If they do that kind of investigative stuff, you're sure to bet if any engine-related hiccups occur, they'll bring that into review and perhaps use it against you for warranty work
The Following User Says Thank You to Koa For This Useful Post:
Teseo (11-30-2014)
Old 11-29-2014, 10:20 PM   #4
frslee
Just drive it
Drives: 13' FR-S
Yeah makes sense. I thought it of as a common sense, but thanks for your responses.
Old 11-29-2014, 10:48 PM   #5
fledonfoot
Drives: Asphalt FR-S
Originally Posted by frslee View Post
Hi,
Toyota service writer here...
No, no flash of the ECU is necessary. The battery will probably be disconnected so it'll have to go through relearn, but we don't reflash the ECU at all as part of the TSB. You should be OK, unless you have one of the very early cars that had a service campaign for a reflash and it hasn't been done yet.
I do, however, advise all of my customers to flash back to stock just to be on the safe side. My techs and I generally try and look the other way with a lot of the aftermarket stuff unless it's glaringly obvious it's causing issues.
fledonfoot is offline   Reply With Quote
The Following 2 Users Say Thank You to fledonfoot For This Useful Post:
frslee (11-30-2014), samisons (11-30-2014)
Old 11-30-2014, 07:03 AM   #6
BRZnut
Drives: BRZ DGM Limited
Sounds like you're one of the good guys!
Old 12-08-2014, 10:09 PM   #7
frslee
Just drive it
Drives: 13' FR-S
So today, the fuel pump was replaced. It was a success! No more cricket noise, just regular tick tick DI noise. We'll see how long it lasts.
Question to whomever has installed the DW 65 fuel pump... Sportsguy83 Engine, Exhaust, Transmission 24 01-18-2015 10:08 PM
Fuel Pump high pitch chirp noise lucius AFRICA 9 10-24-2013 02:40 PM
Should this be covered by warranty and can Subaru repair this? brzadmir Issues | Warranty | Recalls / TSB 16 08-01-2013 12:08 AM
July 10th 2013 new fuel pump same noise instantly dhenson405 Issues | Warranty | Recalls / TSB 59 07-16-2013 03:27 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
