| Southern California SoCal |
Drives: frs
Best Alignment Shop Around San Diego
What's the best place to get an alignment? I have camber bolts and want to get the front set to max negative camber and the rear camber just evened out. Only suspension mod is trd springs.
Thanks
AutoX-10/10ths every run
Alignment Plus in San Marcos, only let Jorge work on your car. He's done quite a few twins and will set it up right.
http://alignment-plus.com/
Drives: frs
Thank you!
#4 | |
Drives: frs
About how much should it cost? I don't want to be given the hey-this-guy-drives-a-new-car price.
Drives: frs
And is there any reason to buy the more expensive whiteline bolts or are the spc camber bolts the same?
Edit: remembered your whiteline sponsorship. It's okay if you'd rather not answer this question, Bob. |
SPC are fine.
Last time I was in there it was $80 for front, $120 for 4 wheel.
Drives: 2015 Subaru BRZ WRB
Best alignment shop in San Diego is Clarence Brown by mitsuwa. When I had my 240sx slammed to the ground with full links and everything they were able to align it to my spec in about 3 hours at a flat rate of $150. If your car is slammed and or has all sorts of adjustable parts on it I highly recommend them. They align it on the ground the old fashioned way and it is amazing.
Drives: fr-s
I hit up Parts Shop Max, Martin does everything right every single time.
| Tags |
| alignment, san diego |
| Alignment Shop Recommendations (San Diego) | RMP | Tracking / Autocross / HPDE / Drifting | 3 | 07-25-2014 04:14 AM |
| Reputable Shop - San Diego | FRSapex | Southern California | 11 | 10-16-2013 12:41 PM |
| Wheels/Tires Shop in San Diego | RacerX | Southern California | 1 | 08-08-2013 02:37 PM |
| San Diego Frame Shop Recommendation | Bakemono858 | Southern California | 4 | 05-05-2013 12:36 AM |
| best tint shop in san diego area | gonzo | Southern California | 8 | 09-24-2012 07:37 PM |
