Old 11-24-2014, 01:58 PM   #1
AznBRZer
Drives: 16 CBS WRX Limited
Need Help with Michelin Warranty
These are Michelin X-Ice 3's that were purchased on 11/27/14 with less than 3000 miles on them. Went back to the place I bought them because it had a weird low speed vibration. They completely missed the weird wear patch the first time and this morning they told me it's from hard braking at high speeds. Sounds like bullshit to me because I don't drive like an asshole. Considering they missed it when they mounted them twice and gave me a balance I didn't need, I'm not so sure I trust their expertise considering they needed to look in a book and didn't bother calling Michelin to try and warranty the tires because the guy said Michelin wouldn't do a thing for me. Knowing how good customer service is with Michelin pro-rating at the very least, I could tell I'm not going to get him to do anything.
Here's a few pics of the wear on one of the wheels and I have the same thing on two of them. I'm guessing they were originally in the rear and pics are from the rear passegerside:
Obviously I'm no expert, but there are some here!
Any help is appreciated.
AznBRZer is offline   Reply With Quote
Old 11-24-2014, 10:28 PM   #2
RJasonKlein
RJasonKlein's Avatar
I assume that you mean they were purchased on November 27, 2013 (not 2014), and I also assume that you mean they have less than 3,000 miles on them now, not when you purchased them. The Michelin X-Ice 3 is an excellent tire, but the individually cut tread blocks will not tolerate much abuse, particularly in the dry. You said that you're not to blame, but the wear appears to be caused by a locked wheel on dry pavement (spinning under acceleration would cause more uniform damage) - are you sure you didn't lock a wheel under braking or slide the car using the parking brake? It's interesting that the tire pictured was on the rear of the car.
Do you have a road hazard warranty? If so, use it. If all else fails, call Michelin's customer service line and make your case, but I think you're going to have a tough time by the looks of it.
Good luck and let us know how things work out for you.
Last edited by RJasonKlein; 11-24-2014 at 10:33 PM. Reason: Realized the poster had addressed one of my questions already.
RJasonKlein is offline   Reply With Quote
Old 11-25-2014, 12:39 AM   #3
Mikeez
Engineering Student
Drives: Scion FR-S 2015
You get warranty for 55 000 km I believe.
Mikeez is offline   Reply With Quote
Michelin PSS versus AS/3 boomslang Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 07-22-2014 11:40 PM
MA: WTB OEM Michelin roflcopter Wheels and Tires 5 02-12-2014 09:48 AM
Stock Michelin Tire Warranty? EAGLE5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-29-2013 05:15 PM
Michelin x-ice CNK86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-04-2013 06:55 PM
Michelin X-Ice 3: 215/50R-17 pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 11-02-2012 10:50 AM
