CANADA Canada
Old 11-24-2014, 01:24 PM   #1
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Anybody using Battery Tender JR?
Hello.
I recently purchased Battery Tender JR to keep my battery active while storing my beauty for the winter.
I searched a lot but there's no review of using on FR-S or BRZ.
If anybody's using Battery Tender on their FR-S or BRZ please let me know if theres any problem occurs.
I'm going to store it for about 4 months. Didn't disconnect the battery just installed right on.
Thanks!
bhbnuckle is offline   Reply With Quote
Old 11-24-2014, 02:21 PM   #2
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Haven't used it on my FRS but always used on 5 other cars with no problems.
Lunatic is offline   Reply With Quote
Old 11-24-2014, 02:26 PM   #3
bhbnuckle
bhbnuckle's Avatar
Did you disconect the battery from hood?
Old 11-24-2014, 02:41 PM   #4
wbradley
Sarcastic SOB
wbradley's Avatar
I am using one going on 3 years now without issue.
The Following User Says Thank You to wbradley For This Useful Post:
bhbnuckle (11-24-2014)
Old 11-25-2014, 11:29 AM   #5
1Cor10:23
1Cor10:23's Avatar
On the topic of battery tenders...what's the best solution for being in shared condo parking w/ no outlets?
Old 11-25-2014, 11:37 AM   #6
wbradley
Sarcastic SOB
wbradley's Avatar
Remove the battery. Keep it on a piece of wood/cardboard (not sure why??). If you want you can hook a battery tender to it in case it somehow starts to drain. When a battery drains down to a certain point it will not hold a proper charge even after jump starting the car and letting the alternator charge it.
1Cor10:23 (11-25-2014)
Old 11-25-2014, 11:48 AM   #7
Lunatic
Lunatic's Avatar
All my batteries were left in the cars and hooked up to the cars.
The Following User Says Thank You to Lunatic For This Useful Post:
bhbnuckle (11-25-2014)
Old 11-25-2014, 02:47 PM   #8
bhbnuckle
bhbnuckle's Avatar
Thank you for the fluent answer!
Old 11-25-2014, 03:22 PM   #9
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Pull the battery out and bring it inside if its stored long enough. Otherwise don't worry about it.
If you absolutely need to use a tender and want to keep the battery in the car I've put my tender under the hood with it before so it didn't get stolen. I recommend covering your ignition to remind you to remove it before starting.
Old 11-25-2014, 03:24 PM   #10
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Diesel generator to run battery tender.
SloS14 is offline   Reply With Quote
Old 11-25-2014, 04:51 PM   #11
1Cor10:23
1Cor10:23's Avatar
Doesn't a tender need an outlet? Thanks.
Old 11-25-2014, 05:39 PM   #12
wbradley
Sarcastic SOB
wbradley's Avatar
yes, thats why you need to remove and bring inside
Old 11-25-2014, 06:03 PM   #13
Reaper
Reaper's Avatar
Drives: violent
Yup that's why I stuffed one under my hood once and ran an extension cord at an apartment complex. So it didn't get stolen.
Old 11-26-2014, 02:56 PM   #14
bhbnuckle
bhbnuckle's Avatar
Do you guys keep B.T hooked in and just leave it for 3~4 months or put away once every certain time?
Battery tender charging through cigarette outlet? imom BRZ First-Gen (2012+) — General Topics 13 01-10-2017 11:18 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Shorai Battery, Tender, and PTuning Tray jack43 Engine, Exhaust, Bolt-Ons 4 08-23-2014 11:42 AM
Suggestion: Marketplace / Tender forum ft_sjo Site Announcements / Questions / Issues 2 08-31-2013 03:03 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
