Old 11-22-2014, 10:00 PM   #1
misooscar
misooscar's Avatar
Drives:
Upgraded cooling fans
I'm looking to track at least 6 timed next year, what's the best upgraded fans for the twins?
Sent from my SGH-M919 using Tapatalk 2
misooscar is offline   Reply With Quote
Old 11-22-2014, 10:25 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Why? Is it overheating now?
Old 11-22-2014, 10:31 PM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Factory fans pull more air than almost all aftermarket fans that fit. The biggest spal fans pull more air but require a customish shroud to be affective. FullBlown makes a kit. Buts if you're having problems fans are the last step. Oil cooler first. Then radiator. Then find a way to get the heat out of the engine bay. Then fans/shroud.
Old 11-22-2014, 10:35 PM   #4
Ultramaroon
not playing cards
^^^this^^^ Oil cooler first and foremost.
Old 11-22-2014, 11:06 PM   #5
misooscar
misooscar's Avatar
Drives:
I have the Vortech 9 psi vishnu tune, perrin oil cooler, vented hood, but stock radiator and fans, I run in hot California tracks in the desert, can be 100 degree plus ambient...
Sent from my SM-N900T using Tapatalk
Old 11-22-2014, 11:16 PM   #6
misooscar
misooscar's Avatar
Drives:
Also , not the Vortech oil fed version 2
Old 11-23-2014, 09:53 AM   #7
Reaper
Reaper's Avatar
Drives: violent
The fullblown radiator shroud and spal fans kit is pretty nice.
Old 11-23-2014, 12:58 PM   #8
sw20kosh
Drives: 2013 Black FR-S
Save yourself the headache and just upgrade that tiny dinky Perrin oil cooler. Even people who are NA and track are realizing that 13 row is too small for the hotter months on the track here in CA.
Get a 15 row or 20 row setrab. You can buy just the core online and swap out your 13 row. Or you can but the Jackson Racing kit.
We have tested time and again on a turbocharged engine and found that an aftermarket radiator like the koyo does not help the engine stay cooler vs the stock radiator. The radiator is not the weak link.
Get those oil temps down and heat won't be an issue.
Radiator Cooling Fans not getting power?? John Rambo Issues | Warranty | Recalls / TSB 13 08-27-2014 10:17 PM
Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires themajesticone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-04-2014 02:49 PM
Any F1 fans here? Shipwreck Hawaii 6 04-09-2013 02:56 PM
Any e30 fans here? streetwaves Other Vehicles & General Automotive Discussions 83 12-12-2012 11:30 AM
Any UFC fans? Enemies Off-Topic Lounge [WARNING: NO POLITICS] 13 06-25-2012 11:21 PM
