View Poll Results: Which wheels looks nicer?
RS05RR 36 64.29%
Gram Light 57xtreme 20 35.71%
Voters: 56. You may not vote on this poll
Old 11-22-2014, 12:13 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Help me buy wheels...Come vote.
RS05RR VS Gramlight 57xtreme
I wish I could get many wheels, but unfortunately I can only afford one set. I will be going with the Enkei RS05RR Wheels 18x9.5 square setup. I will have the +43 offset. Should I get spacers for the strut suspension or just get a set of coilovers. I will be getting BC BR Coilovers. I don't want weird sounds or annoying sounds from the suspensions...
Mikeez is offline   Reply With Quote
Old 11-22-2014, 02:31 PM   #2
djdnz
1337
Drives: 2013 BRZ WRB S/C
Get the right offset wheels, don't get spacers.
djdnz is offline   Reply With Quote
The Following 2 Users Say Thank You to djdnz For This Useful Post:
hmong337 (11-22-2014), JohnJuan (11-24-2014)
Old 11-22-2014, 02:48 PM   #3
bansky
bansky's Avatar
Drives: 2.0 MT 2012
[SIZE=2]Which spacers should I get :3
8.75 +35 front
8.75 +20 rear
will fit on stock
use this http://www.frsproject.com/tire_size.php
mb XXR550?
bansky is offline   Reply With Quote
Old 11-22-2014, 05:36 PM   #4
Mikeez
Engineering Student
Lol yeah.. :3 which offset
Originally Posted by a.k. View Post
8.75 +35 front
8.75 +20 rear
will fit on stock
mb XXR550?
I don't like XXR and I like enkei for the light weight designs.
I will be going RS05RR from Enkei
For the rear: 18x9.5 +43
5x100 bolt pattern
Old 11-22-2014, 05:53 PM   #5
bansky
bansky's Avatar
Drives: 2.0 MT 2012
5x100 bolt pattern
18x9.5 +43 all around
*from Assunta
Old 11-22-2014, 05:53 PM   #6
Mikeez
Engineering Student
I can't get a perfect staggered fitment... Originally the fender gap is the same if you use allaround same wheel... right?
I want 8.5 front and 9.5 front (both 18") wheels... I always get a variation. I don't know if it is negligible but it is 1cm (8mm)
Anyways
18x9.5 +43 rear
18x8.5 +42 front
265/30/18 rear
235/35/18 front
Right, wrong.. no? XD
Old 11-22-2014, 05:54 PM   #7
Mikeez
Engineering Student
*from Assunta
I saw the pics from the ft86speedfactory thread
Old 11-23-2014, 09:20 AM   #8
jdmblood
jdmblood's Avatar
Drives: white subaru brz
Go square so you can rotate your tires. Staggered setups understeer if I'm not mistaken. And go enkeis..
jdmblood is offline   Reply With Quote
Old 11-23-2014, 01:23 PM   #9
Mikeez
Engineering Student
What about 18x9 front and 18x9.5 rear
.5 makes a difference?
Its decided I will be going Enkei RS05RR... I know I need coilovers or else they rub on the strut of the suspension?
Old 11-23-2014, 07:17 PM   #10
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Voted RS05RR because they're more unique at the moment. Seems like every second ZN6 has 57Extremes.
Wise is offline   Reply With Quote
Old 11-23-2014, 07:21 PM   #11
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I like both wheels but only with 9.5" width. The more narrow sizes have no concave and aren't very good looking in my opinion.
I'd also run the square setup as staggered size has its drawbacks.
I'd almost say RS05s simply cause they aren't as common but ou can go wrong either way. Both are quality products from reputable companies
TylerLieberman is offline   Reply With Quote
Old 11-23-2014, 09:07 PM   #12
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
How is having a square setup better than a staggered setup? I like the general no rice mentality of the forum, but everyone swears they are some kind of track guru. Who are you kidding? Most of us DD with an occasional mountain run or autocross. I run 18x8 et45 225/40 and 18x9 et42 245/40 because that's what I enjoy
Get which ever one you like the most. The realistic drawback to a staggered setup is rotating, especially if you have directional tires. Otherwise do what you flipping want to do. Just don't go with an offset lower than +35 (and even that is pushing it in my opinion) or you'll poke the car next to yours.
If I were to do a dedicated track build, I wouldn't even have 18's...
Just a rant...not targeted at anyone.
The Following User Says Thank You to boredom.is.me For This Useful Post:
continuecrushing (11-24-2014)
Old 11-24-2014, 08:00 AM   #13
CSG David
CSG David's Avatar
Do you want some TWS T66-F for weight savings and incredible strength qualities? :p
The Following 2 Users Say Thank You to CSG David For This Useful Post:
chaoskaze (11-28-2014), tahdizzle (11-24-2014)
Old 11-24-2014, 01:35 PM   #14
Mikeez
Engineering Student
Sounds like an Engineer. Yes, the only drawback of the staggered set up is rotating. However, there is a little instability. Track car are usually more tires and less wheel =p. You're right again, but the difference is negligible for me since I won't track
Thanks everyone for your inputs, I've updated my thread. I will get square setup 18x9.5+43
Should I get BC Coilovers? Or spacers? I heard it rubs on the strut of the suspension.
The Following User Says Thank You to Mikeez For This Useful Post:
boredom.is.me (11-24-2014)
I need your vote! finch1750 Northern California 15 07-31-2013 08:17 PM
Please Vote For My Friend! husker741 Off-Topic Lounge [WARNING: NO POLITICS] 8 04-19-2013 07:57 PM
please vote #1! bakerr6 Other Vehicles & General Automotive Discussions 0 03-04-2013 09:01 PM
Another PNW Car meet? Vote on a date and vote on what to do! NickFRS Northwest 45 01-07-2013 07:23 PM
