Old 11-21-2014, 02:03 PM   #1
fang_gt86
FR Noob
fang_gt86's Avatar
Rear Mount Hydraulic Turbo?
I'm wondering if a rear-mount hydraulic driven turbo like my concept below can possibly work? This isn't anything serious just a fun concept!
I think some of the obvious benefits are things like less heat in engine bay and better weight distribution.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 11-21-2014, 02:06 PM   #2
tobin
tobin's Avatar
Drives: '13 BRZ
Dude you should patent that immediately.
tobin is offline   Reply With Quote
The Following User Says Thank You to tobin For This Useful Post:
fang_gt86 (11-21-2014)
Old 11-21-2014, 02:29 PM   #3
To late, it is now public domain as he posted on the forum without copywrite or patent!
Old 11-21-2014, 03:34 PM   #4
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
You have to wonder why no one has done this before if it was actually viable.
Even an accessory driven hydraulic pump could work.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 11-21-2014, 04:22 PM   #5
Well apparently if you attended the 2002 SAE Powertrain and Fluid conference (sounds like a blast) then you would have heard a paper discussion on the topic. Apparently didn't pan out as there was very little info on the topic to be found. There is however a patent filed for a hydraulically "assisted" turbo.
And a similar idea has been knocked around on other forums.
http://papers.sae.org/2002-01-2731/
http://www.google.ca/url?sa=t&rct=j&...80185997,d.cWc
strat61caster (11-24-2014)
Old 11-21-2014, 04:26 PM   #6
jvincent
jvincent's Avatar
There is a one year grace period in the US, so he has some time.
Old 11-21-2014, 05:18 PM   #7
fang_gt86
FR Noob
fang_gt86's Avatar
It's not a simple design for sure. Way more parts comparing to traditional setups.
Old 11-21-2014, 05:20 PM   #8
fang_gt86
FR Noob
fang_gt86's Avatar
It's just an idea for discussion.
Old 11-21-2014, 05:24 PM   #9
Cool idea, that is why I tried to find more on the subject. Not a lot of info out there though.
Old 11-21-2014, 06:13 PM   #10
Foobar
SLO NO MO
Foobar's Avatar
Would the hydraulic fluid move fast enough to charge the blower to sufficient speeds?
Old 11-21-2014, 08:14 PM   #11
fang_gt86
FR Noob
fang_gt86's Avatar
Yeah, I had that same doubt too. Maybe geared the turbine pumps so the fluid will reach the blower at faster speed?
Old 11-21-2014, 08:59 PM   #12
serialk11r
Drives: '06 AM V8V Coupe
Instead of a shaft (100% conversion efficiency), you are using a pump and a turbine which has considerable losses through flow viscosity and "leakage" at the pump and turbine. It would be better to use an electric generator and motor pair which would have maybe 85% efficiency.
The Following 2 Users Say Thank You to serialk11r For This Useful Post:
cdrazic93 (11-25-2014), strat61caster (11-24-2014)
Old 11-21-2014, 11:48 PM   #13
DAEMANO
Time Traveller
That idea has a familiar ring to it.
Old 11-22-2014, 12:27 AM   #14
stugray
Drives: 2013 GBS BRZ Limited
They are doing that exact idea, but replace the pipes with solid copper and the hydraulic fluid with electron fluid :-)
This has some info:
http://www.heat2power.net/en__benchmark.php
The electric turbo compounding.
Now you can isolate the intake impeller from all of that heat
Hydraulic Hand Brake? Gillams Scion FR-S / Toyota 86 GT86 General Forum 2 09-18-2014 04:47 PM
AVO Turbo Front Mount Intercooler (BRAND NEW) tamsau Engine, Exhaust, Bolt-Ons 1 06-18-2014 10:53 PM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 01:37 AM
OEM hydraulic hood props ML Cosmetic Modification (Interior/Exterior/Lighting) 4 07-23-2013 09:24 AM
