Old 11-21-2014, 01:25 PM   #1
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
How to remove front rotors?
I have track day tomorrow and cannot find a guide on how to remove front rotors on the FRS. Please help I need to find this ASAP thank you. Already removed the caliper, just don't know what the two little screws or whatever they are are on the rotor itself so I can pull it off. Thanks again and sorry if this is a repeat thread. Cannot find anything... I need to know first what they are, then what size they are so I do not strip them out.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 11-21-2014, 01:31 PM   #2
JOSEC
Drives: 2014 Subaru BRZ WRB
http://www.ft86club.com/forums/showthread.php?t=45713
Installed my AP Sprint kit a couple of weeks ago. This helped a lot. I got stuck at removing the rotors as well.
I believe I used the caliper bracket bolts to remove them. It felt like it was cross threading when I was screwing it on. But I kept checking it and it was fine.
JOSEC is offline   Reply With Quote
Old 11-21-2014, 01:34 PM   #3
BuBlake
BuBlake's Avatar
Thank you! Looks like mine are either seized or I haven't pulled on it hard enough yet.
Old 11-21-2014, 01:39 PM   #4
JOSEC
They're on there pretty good. Took a lot of force to take off. I used lots of liquid wrench as well. Any penetrating oil would work. Don't forget to clean the hub with brake cleaner after. Good luck!
Old 11-21-2014, 02:56 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The two screw holes allow you to "push" the rotor off the hub. It's stuck because of surface rust.
-alex
Old 11-21-2014, 05:09 PM   #6
swarb
rubber mallet to the back of the rotor.
Old 11-21-2014, 06:08 PM   #7
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
This.
dradernh is offline   Reply With Quote
New 97 non turbo supra front rotors x 2 njccmd2002 Miscellaneous 0 08-07-2013 09:55 PM
Dimensions of stock front rotors? ft_sjo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-19-2013 02:49 PM
[WA] FS: GTS Front AND Rear Rotors stevo_12v Australia Classifieds 0 01-04-2013 08:43 AM
Replacement Front Rotors Texas BRZ Tracking / Autocross / HPDE / Drifting 40 11-27-2012 03:44 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 05:20 AM
