Old 11-17-2014, 11:51 PM   #1
Akari
Drives: 2013 DGM BRZ
Looking for BRZ heated seat information
As most of us BRZ Limited owners know the OEM heated seats don't really get more than warm or stay consistently hot. I'd love to figure out a solution to turn these up but I've not yet fully come to understand how the heat is controlled. From the wiring diagram we only get to see power from the switch going into the seat so the key must be in the seat itself.
Does anyone have any info on electronics within the seat? Has anyone found a thermostat in a seat or any other electronics that are being used to regulate temperature?
Akari is offline   Reply With Quote
Old 11-18-2014, 12:01 AM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
You want it HOTTER?! Honestly I rarely ever feel the need to even use the HI setting. And I live in Chicago!
Stang70Fastback is offline   Reply With Quote
Old 11-18-2014, 12:12 AM   #3
Akari
Mine get luke warm with the occasional burst of hot(maybe once or twice a day it seems). Every single other vehicle with heated seats I've ever been in get much, much hotter.
Old 11-18-2014, 12:14 AM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yeah, but it's a dry cold for you. It's that damp cold up here in the NW that just chills to the bone. Brrrrr!
Old 11-18-2014, 12:42 AM   #5
Ultramaroon
not playing cards
I did a quick check of the wiring diagram and it doesn't look like there's any thermostat unless it's integrated with the butt warmer itself.
One telling symptom is your report of an occasional burst of heat. That sounds to me like an intermittent connection. If the connection is loose for a device that draws as much current as a heater, you might find signs of heat in a connector or a ground lug. These can be a real PITA to trace.
Old 11-18-2014, 12:52 AM   #6
Akari
Yeah, I'll double check the connectors again but it could be something internal to the seat not functioning correctly. From reading all the other threads on our seats they seem to be really hit or miss between people, some barely work and some are hotter than people can stand.
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
Part number request for heated seat switch trim azian_advanced Cosmetic Modification (Interior/Exterior/Lighting) 1 09-13-2013 11:02 PM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
Need a BRZ owner with heated seat controls for blueprinting. yospeed Southern California 12 02-23-2013 08:29 PM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
