| NY / NJ / CT / PA NY, NJ, CT, PA |
Drives: 2013 WRB BRZ
Winters without a garage
So I live in Nj and I dont have a garage. The Brz is my daily (have a forester for really bad snow). Anyway, how are you guys preparing for winter? I would hate to see the car sitting outside in the snow. Should i be worried about rust? I also have coilovers on should i buy antiseize and spray down the bolts? Any other guys on here with the same problem?
-Dave |
Drives: subaru
Snow isn't really the issue, it's more so the salt. Give the car a wash once a week to get all the salt off and you should be good to go
Drives: 2014 Scion FRS
in my past experiance, i havent really had to use any kind of anti sieze on coilovers,
use a nice pressure washer once or twice a week before lowering or raising the car, make sure the coilovers are clear of debris, use a tooth brush to clean |
Undercoating!
Drives: 13 Subaru BRZ, 02 Audi TTQ
If there's enough snow you won't see it
Drives: SWP BRZ
holy moly
Drives: Whiteout 6Sp FR-S
I would be more worried about some idiot hitting it at night because they cant drive in ice and snow and then running off without a note or anything. Oh wait that what happened to mine last year with only 800 miles on it.
the tuna, no crust.
Drives: 2014 Hachiroku of the year
i give the car a serious detail before winter then i just power wash it all winter long. get in all the nooks and crannys so that salt gets washed off.
i personally switch to stock suspension, other wheels/tires and remove all aero. depending on what coilover you have i'd recommend you swap back to stock. salt can really fuck your shit up if you don't maintain it, the last thin you want is a seized coilover. just keep up with rinsing salt off basically. you'll be fine as long as you have good tires on the car. |
Drives: Silver BRZ
Mine will be spending the winter in the garage under a california car cover. I will be needing to power wash it underneath as tonight I got to drive home thru a bunch of salted roads. Uggh, It's still too early for this!!!
Give her a good detail and a coat of wax. I'd also wash it thoroughly underneath periodically to wash away the salt. I like the automatic washes with the chassis spray. Coil overs should be fine, clean well before making any adjustments.
When exactly did Custom become a four letter word!
#10 |
I have heard of people plasti dipping their wheels and if they have to drive you could plastidip the car. This will protect the outer coat and can be removed in the spring. Plus it gives you a different look. I saw a place in soth NJ that will dip the car for like $500
#11 | |
#12 |
#13 |
Drives: 2014 FR-S
Like a lot of others said. When the weather gives you a chance, give it a wash. Mine stays outdoors, and we get considerably more snow up by me. And, while I have no experience with coilovers, it does seem prudent to go back to stock suspension for the winter. When I lived in NNJ, the policy was to pile the salt up higher than the snow by simply tipping it out of the dump truck. Free temporary speed bump.
-Mike
#24 CS/CSR |
#14 |
Member of the year - 2016
Drives: Scion FRS
I just go to a DIY car wash and rinse down the salt with the power wash. I don't use the soap because it'll remove my sealant.
| After driving my frs last two winters, finally got myself a beater! | powerj2 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 09-23-2014 08:08 AM |
| FS [Vancouver BC] - Strut Bars, Catch Can, Crank Pulley, Winters, Oil Filters | Ravenlokk | Canada Classifieds | 4 | 05-28-2014 03:53 PM |
| Question: Will 225/45 or 225/50 winters tires fit the stock wheels?? | wbradley | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 12-30-2013 03:13 PM |
| Getting new 16" wheels with winters, do I need to do wheel alignment? | amram | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-23-2013 01:17 PM |
| FS Ottawa area: Winters on steelies. | Skyllz | Canada Classifieds | 0 | 09-09-2012 09:14 PM |
