Old 11-16-2014, 08:21 PM   #1
FrSnake
Resident Noob
FrSnake's Avatar
Drives: Satin White BRZ Limited
ARP Extended Wheel Studs
I just had a quick question. If anyone could answer, I'd appreciate it.
I need to put spacers (10MM) on my front and back to get enough space to run my new rims. I would like to know what lugs the ARP extended lugs required: closed or open? I read somewhere (not sure where) that the wheel studs like the ARP ones that have the space on the end require a certain lug. Not sure which though so help please!
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust
“Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson
FrSnake is offline   Reply With Quote
Old 11-16-2014, 08:21 PM   #2
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Open
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
FrSnake (11-16-2014)
Old 11-17-2014, 11:51 AM   #3
wparsons
wparsons's Avatar
Unless you're running thick spacers, you'll need open ended lugs for the ARP studs.
flickr
WTB: ARP extended wheel studs mikep Canada Classifieds 2 05-22-2014 01:00 PM
FS: Extended 12x1.25 studs BlueDubbinTDI Brakes, Suspension, Chassis 9 04-03-2014 10:27 PM
can't find 8mm wheel spacers that include extended studs BlueDubbinTDI Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-03-2014 12:16 PM
non-extended wheel studs BadCompany235 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-14-2013 08:02 AM
Extended studs with stock setup eckoflyte Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 05-10-2013 09:13 AM
