Old 11-09-2014, 10:09 PM   #1
chicagokid
Club Member
chicagokid's Avatar
Drives: 2014 Asphalt FR-S Monogram 6MT
Help... Which one is the ground wire on the stock wiring?
not the one attached to head unit, but the wiring behind the dash.
Thanks...
chicagokid is offline   Reply With Quote
Old 11-10-2014, 06:48 AM   #2
Chimera
Drives: FRS
What are you attempting? If you just need a ground, find a bolt touching metal and wire a terminal to it. Find an unpainted surface, there are lots of options behind the dash.
Old 11-10-2014, 01:47 PM   #3
chicagokid
Club Member
chicagokid's Avatar
Thanks... I actually found the wiring diagram. Ground is the black/blue wire. I did have the ground (from head unit) attached to metal behind dash, but the HD channel was not coming in good. Now I attached the head unit ground to the car's wiring harness (black/blue) and HD comes on and stays on.
Reusing stock speaker wiring - Aussie 86 Z86 Electronics | Audio | NAV | Infotainment 16 08-16-2022 01:28 AM
Selling Stock Taillights (No wiring or bulbs) asphaltkyle Exterior Parts (Aero, Lighting, Etc.) 4 06-06-2014 04:38 AM
Hardwiring V1 - BRZ ... Ground wire? KSpider Electronics | Audio | NAV | Infotainment 5 09-15-2013 09:36 PM
Ground clearance? RT87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-28-2012 04:13 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
