Old 11-06-2014, 12:18 PM   #1
Drakelee117
Drives: Subaru BRZ 2015
Anybody knows what type of brake fluid our car have?
I was talking to a track day group about if I need to do anything to the BRZ to make it track-ready. They told me I am most likely be needing to change my brake fluid to a synthetic type fluid. Anybody know what type is in the stock cars? And if I go buy the fluid myself will the dealership be able to change it for me? (I just hit 3200Miles so I am planning to get the service done before my track day)
Drakelee117 is offline   Reply With Quote
Old 11-06-2014, 12:36 PM   #2
gramicci101
Off Topic
I wouldn't go to the dealer. They'll ask uncomfortable questions like, "Why does it need to be changed at 3200 miles?" And "Oh, you're tracking it? Let me make a note of that for any future warranty claims."
Beyond that, refer to @CSG Mike's thread about track prep: http://www.ft86club.com/forums/showthread.php?t=25485
The Following User Says Thank You to gramicci101 For This Useful Post:
CSG Mike (11-06-2014)
Old 11-06-2014, 12:39 PM   #3
jvincent
jvincent's Avatar
The owners manual will give the specs for the OEM brake fluid.
The track thread is a good one to read. On the specific topic of brake fluid you need to have high temperature racing fluid.
Also important are upgraded brake pads. Unless this is your first time at the track, you will probably end up fading the stock pads.
Old 11-06-2014, 12:39 PM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
Yes 100% change the brake fluid and get better brake pads. Don't be like the countless first timers that have a bad day because they boil their fluid and smoke their pads.
Old 11-06-2014, 12:41 PM   #5
White64Goat
Kind of depends what type of track, how hard you will run the car/braking ambient temperature, mileage on stock pads etc, etc. (In other words---variables). I ran my first HPDE at Summit Point last November on the main circuit and ran stock pads and fluid and only had one time in two days where I thought the pedal got just a little soft. Am still driving on those pads. I bought upgraded brake lines and fluid (Motul 5.1) from Mach V Motorsports in Virginia to change them but lost use of my garage last spring/summer due to addition being added over the garage.
You might want to PM DAVE-ROR on here and he can possibly steer you to reputable places in Florida to deal with. Check the Southeast forum section too.
Old 11-06-2014, 12:43 PM   #6
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Use DOT 4 or DOT 5.1 but do NOT use DOT 5, as it is not hygroscopic and will allow condensation to build up in your system until it possibly causes corrosion or until you flush it.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 11-06-2014, 01:20 PM   #7
White64Goat
Check this thread..........http://www.ft86club.com/forums/showthread.php?t=22137
Old 11-07-2014, 12:10 AM   #8
Poodles
Drives: 2015 Series.Blue
DOT 3 from the factory. DOT 3, 4, and 5.1 are interchangeable and compatible with each other in a pinch.
DOT 5 is silicone based and not for use in ABS systems as it foams.
Old 11-07-2014, 09:10 AM   #9
Lebby83
Drives: 2019 BRZ, 2016 Touareg
How many liters does the BRZ take?
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
Old 11-07-2014, 10:07 AM   #10
jvincent
jvincent's Avatar
1L is more than enough to do a full flush. If you are really careful you might be able to do it with 500ml.
Old 11-07-2014, 10:12 AM   #11
Lebby83
Okay. Thanks!
Rob
2016 VW Touareg TDI
Brake Fluid Flush protpibe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 01-02-2014 02:19 PM
Cooked my brake fluid!!! markitect Tracking / Autocross / HPDE / Drifting 18 07-11-2013 10:53 AM
Track Day Brake Fluid Skorov AUSTRALIA 2 11-11-2012 07:10 PM
$98 Brake Fluid Upgrade Texas BRZ Tracking / Autocross / HPDE / Drifting 15 10-22-2012 02:50 AM
Brake fluid volume celica73 Tracking / Autocross / HPDE / Drifting 1 08-20-2012 02:05 PM
