Old 02-20-2013, 02:33 AM   #1
itisthumper
itisthumper's Avatar
Drives: WRB BRZ MT
What tires for 17x8 +42 Work Emotion CR Kai
I need a set of cheap all season tires for these wheels. Im looking to pay $400. And should I go with 225/45 for a neutral look? It will be dropped 1" all around.
itisthumper is offline   Reply With Quote
Old 02-20-2013, 06:50 AM   #2
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Size is good, check out the nitto motivo from discount tire they should be close to 400.
JoeBoxer is offline   Reply With Quote
Old 02-20-2013, 07:06 AM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
Kumho Ecsta 4X are $107/each from Tire Rack, tested very well:
http://www.tirerack.com/tires/tests/...y.jsp?ttid=151
Old 02-20-2013, 11:05 AM   #4
itisthumper
Drives: WRB BRZ MT
How do these tires hold up in longevity? I dont plan on changing the tires for a while
Old 02-20-2013, 11:13 AM   #5
JoeBoxer
JoeBoxer's Avatar
Motivo is the evolution of Nitto's Ultra High Performance street tires engineered to perform in all weather conditions while providing ride comfort, minimal road noise, and increased mileage. Motivo's all-season capability fulfills the demands of your active lifestyle by navigating you safely through challenging road and weather conditions.
The Motivo is available with a 60,000 mile limited treadwear warranty, the industry's #1 warranty for all-season performance tires*.
UTQG Treadwear: 560
Traction: A
Temperature: A
*Nitto Motivo 60,000 mile limited treadwear warranty. Longest treadwear warranty among all manufacturer published (as of May 2012) warranties for W & Y speed rated all-season ultra high performance tires. Please refer to Nitto's warranty manual for full details
The Following User Says Thank You to JoeBoxer For This Useful Post:
itisthumper (02-20-2013)
Old 02-20-2013, 11:20 AM   #6
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
if i were yo i'd go with a 235 instead.
Jive Turkey is offline   Reply With Quote
Old 02-20-2013, 05:54 PM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
420 treadwear, AA traction rating, 40k mile warranty. Rated pretty decently for treadwear in customer survey results: http://www.tirerack.com/tires/survey...=true&filter=y
Another option: General G-Max AS-03. Just got a set of these for wife's Mazda3. Also tested very well, a bit higher rated for life.
480 treadwear, A traction rating, 40k mile warranty
$10 more per tire than the Kumho Ecsta 4x
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 17x9.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 10-31-2019 04:22 PM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 03:14 AM
Wheel Directory: Work Emotion XC8 18x?.? +?? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-14-2012 01:42 AM
WORK Emotion CR Kiwami Kenno AUSTRALIA 54 08-20-2012 07:54 PM
EOI: Work Emotion CR-Kai 18" Panman Australia Classifieds 11 07-31-2012 08:13 AM
