Old 10-30-2014, 06:01 PM   #1
PantsDants
Drives: Scion FR-S A/T, Whiteout
Go home OFT you're drunk
Source: http://datazap.me/u/pantsdants/10-30...om=15625-16323
It looks like I intermittently lost connectivity between the car and OFT while driving up a hill on the freeway. Either that or my car is going to explode. This is the only spot in the log where this occurred, and I didn't notice the car acting weird at any time while I was logging. Any ideas? Is it just a loose wire in one of the plugs?
OFT is on latest firmware and template file. Tune is a tweaked version of the OFT ESC 91 octane map.
PantsDants is offline   Reply With Quote
Old 10-30-2014, 06:25 PM   #2
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
What the! Also notice that your MAF voltage goes to zero around the time of the drunk readings. Oddly enough, near the end you were still getting reasonable engine load readings even though the logs say you had a MAF voltage of zero. What this tells me is that the MAF sensor is probably still working even when logging 0 because it plays a big part in engine load. Must be a cable connection or a problem of the like. Probably nothing under the hood.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 10-30-2014, 08:09 PM   #3
Anh5oi
Drives: 13 FRS
Have you check all the connectors on the MAF sensor?
Current: FRS(Daily), Cayenne(Weekend), 1000RR(Fun), 650Maxim(Fun).
Recently Sold: 13 Boxster(Crash), 08&10 335i, 08 M3, 12 A4, 97 NSX....
Anh5oi is offline   Reply With Quote
Old 10-30-2014, 08:42 PM   #4
phrosty
You can see RPM dropping out as well. OFT may have had a loose connection, hopefully it's nothing serious
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 12-21-2014, 01:29 PM   #5
Koa
Have you solved this problem? I'm having the same problem, car runs 'great', but MAF voltage is reporting zero
http://datazap.me/u/koa/3rd-4th-pull...log=0&data=1-2
Old 12-21-2014, 06:02 PM   #6
PantsDants
Kind of? I have an extension cable plugged onto the OBD port at all times; I just pressed up on it firmly and the drop-outs I was seeing haven't come back since. Our OBD plugs feel super flimsy so be careful with that though.
The Following User Says Thank You to PantsDants For This Useful Post:
Koa (12-22-2014)
Whiteout FRS hit by drunk driver.. What to do? Randyliciious Scion FR-S / Toyota 86 GT86 General Forum 34 12-12-2013 04:07 PM
im drunk BRZPDX Northwest 10 12-09-2013 12:21 PM
Im super drunk Exhaust Off-Topic Lounge [WARNING: NO POLITICS] 5 04-02-2012 09:15 AM
Anti-drunk drink?! O_o 4point8 Off-Topic Lounge [WARNING: NO POLITICS] 2 12-04-2011 12:24 AM
