Old 10-30-2014, 04:35 AM   #1
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Cold Start Exhaust Tones
Wondering what you guys think of cold start tones on aftermarket exhaust. Watched about a million videos with a million different exhaust setups and 99% of them sound like semi trucks pulling a load at idle. No doubt I want to wake up the neighborhood under full throttle, but do I have to sound like a "header-back-delete" every time I press start? Thoughts/suggestions?
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 10-30-2014, 05:07 AM   #2
steve99
High Rev Cold Start noise reduction
Noisy high rev cold start is to warm up Cataylic converters for emissions purposes
http://www.ft86club.com/forums/showp...6&postcount=17
Three things happen Idle is increased to 1700rpm
Additional Fuel is added by offsetting MAF scale during warm-up
Ignition Timing is retarded by 15 degrees during warm-up
The retarded timing is what makes most of the additional noise.
To fix alter the “Ignition Timing Post Start” table under “Ignition Timing- Advance” folder .
Change all cells from -15 to -4 degrees and most of the noisy “bark” should be gone.
.This image has been resized. Click this bar to view the full image. The original image is sized 1600x900.This image has been resized. Click this bar to view the full image. The original image is sized 1600x900.
You can also reduce the “Idle control” “Idle control Target A” and “Idle control Target B” tables reduce the values for idle that are over 1400 rpm to 1400 rpm. You could go down to 1200 rpm but then need to alter tables A though E.
The MAF adjustments can also be scaled back by altering the MAF correction after start neutral and in gear tables as above.
you might want to leave some maf correction in if your in cold climate.
Don’t get to aggressive with your adjustments else your car may not idle well in very cold weather startup and you may also trigger a CEL code related to cat warmup.
Whole thread on it here.
http://www.ft86club.com/forums/showt...rev+cold+start
Old 10-30-2014, 05:26 AM   #3
poorsche
poorsche's Avatar
Thanks, that was so thorough! I'm using ecutek right now, but didn't tune the car personally. How do I transition from paying for tuning to doing it myself. Basically what do I need to be setup for DIY? Already have cable and license. I know this is a rookie question but I've never had a car that required much more than mechanical aptitude.
Old 10-30-2014, 06:05 AM   #4
akahenry
akahenry's Avatar
Drives: '18 STi
lol I agree. The aforementioned post looks so in depth that nubs like myself can't possible decipher what is what haha.
akahenry is offline   Reply With Quote
Old 10-30-2014, 06:25 AM   #5
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You can get started by following the links in his signature.
Old 10-30-2014, 07:09 AM   #6
steve99
You can make all those adjustments with Ecutek, the table names might be slightly different.
If you already have Ecutek cable and license you could make changes, the only thing that might stop you is your tune may be locked by your tuner so you may only be able to flash your tune but not make changes to that particular locked tune. you could always ask your tuner to make those changes shouldn't cost much
I'm not familiar with Ecutek but talk to @Kodename47 he is a very helpfull Ecutek guy.
Old 10-30-2014, 12:19 PM   #7
mid_life_crisis
Drives: FR-S 10 #103 AT
Just be aware that the "MAF Correction after start" tables are only for manual transmission vehicles.
Old 10-30-2014, 10:32 PM   #8
steve99
I believe those tables are in all rom just not defined in the OFT definitions
Old 10-30-2014, 10:49 PM   #9
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
If you're not into tuning, you can just put the car and gear and drive away right when you turn it on. As an AT owner, i just put my car into reverse right when i start it so i don't wake up anyone. i only have a highflow cat and resonator delete, yet it can be quite loud.
You're not suppose to warm up your car by idle anyways...start driving right away.
Old 10-30-2014, 11:01 PM   #10
mid_life_crisis
Ahh, I didn't check to see if they were in the MT versions for the OFT.
I'll have to do that in the morning.
Edit: Finally got around to checking, and they are missing from the MT versions as well, so disregard my earlier post.
It isn't the transmission, it's the OFT definitions.
Old 10-30-2014, 11:31 PM   #11
phrosty
If you normally give it a tiny bit to warm up before putting the car in gear, you can get by changing only the neutral table. That's what I did.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
cold start, exhaust, exhaust drone, front pipe, header
Exhaust rattle on cold start? Laurie Scion FR-S / Toyota 86 GT86 General Forum 8 12-04-2020 07:15 PM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Exhaust vibration/rattle at cold start? Foobar Engine, Exhaust, Transmission 7 04-16-2013 05:15 PM
Cold Start Exhaust Volume SilentMike Engine, Exhaust, Transmission 15 04-04-2013 10:49 AM
