Old 10-29-2014, 03:48 PM   #1
lp87
Drives: 2013 swp brz
CEL and cruise control not working
So I installed a jdl equal length header about a month and a half ago (with o2 spacer) and just got a cel yesterday, which I assume to be from the header. Only other engine modification is a catback. Also, when I press the cruise control button, the icon on the dash lights up amber, and won't go away until the car is turned off. Anyone have any ideas about why cruise control no longer works? Thanks for any help in advance
lp87 is offline   Reply With Quote
Old 10-29-2014, 05:09 PM   #2
lightdir
Drives: 2013 Raven FRS 6MT
it is because of your CEL
lightdir is offline   Reply With Quote
Old 10-29-2014, 09:38 PM   #3
steve99
above post is correct.
you need to disable cel in software its code P0420 or try an 02 sensor spacer in the rear 02 sensor to fool ecu that you still have cat. try the different size washers if it came with them. to reset the cel remove batt cable for a minute or pull the ecu fuse, then you wont have to reset radio ect.
Old 10-30-2014, 01:48 PM   #4
lp87
So if I pull the ecu fuse and put it back the cel will go away?
Old 10-30-2014, 08:08 PM   #5
steve99
it will clear cel but if its a permanent problem it will come back
Old 12-01-2014, 11:09 AM   #6
lp87
If you disable the software code does that mean the cel won't be functional if the engine has other problems unrelated to the header? Is fixing it with the o2 spacer the only way to fix it correctly then? the CEL goes away and comes back pretty frequently now
Cruise Control 'set' light LeftFootBrake Issues | Warranty | Recalls / TSB 28 11-27-2015 08:38 AM
Cruise Control nospoons Scion FR-S / Toyota 86 GT86 General Forum 34 06-17-2014 02:28 PM
Cruise control notout86 Scion FR-S / Toyota 86 GT86 General Forum 50 05-13-2013 02:01 AM
You guys with Limiteds, hows your climate control working? houseofsuffering BRZ First-Gen (2012+) — General Topics 58 02-22-2013 08:37 AM
Ground Control is working on some stuff for us :) D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-24-2012 06:21 PM
