Old 10-27-2014, 03:01 PM   #1
nick61416
AMP wiring help for tablet install
I am currently in the process of installing my nexus 7 tablet in my car as a replacement headunit. I am having some trouble with the wiring and unable to find the correct/any information. My plan is to use a USB DAC with my nexus 7 which will run directly to an amplifier, no headunit installed. I will keep the OEM speakers for right now, until I buy a 2-way component set for the front and new speakers for back.
Here is where I am having my issues. How do I wire the amp to the speakers? My amp is in my trunk, so I ran 4 sets of speaker wire to behind the stock headunit (will be removed). Can i just buy a wiring harness and just wire the speakers that way? Or do i need to bypass the OEM amp or crossovers?
nick61416 is offline   Reply With Quote
Old 10-27-2014, 03:08 PM   #2
Chimera
Drives: FRS
Your going to need an aftermarket amp, the stock one will not do what your trying to do. wire signal from your DAC to an aftermarket amp, then on to speakers as per normal. You could wire the amp to a metra kit then to the stock HU harness. I don't recommend as it will actually complicate the thing in the long run, but you could.
Old 10-27-2014, 04:53 PM   #3
nick61416
Sorry I forgot to mention that I already have an aftermarket amp. It is currently wired to the USB DAC from the nexus 7. I was mainly curious of the easiest way to wire that amp to the OEM speakers. I already ran speaker wire from amp to the headunit location. Are all the necessary speaker wires loacted behind the dash, and do i need to do anything with the OEM amp?
Old 10-27-2014, 05:17 PM   #4
Chimera
Drives: FRS
then you need to wire those speaker wires to a Metra 70-1761. it will connect to the stock HUs connectors
the factory amp.. you could bypass it but then you might damage the speakers, it has a low pass filter built in, probably best to leave it there for now.
Old 10-27-2014, 11:24 PM   #5
lightdir
Drives: 2013 Raven FRS 6MT
removing the stock Head unit will disable some of the factory speakers.
the factory amp in the trunk of the car does not power all the speakers.
lightdir is offline   Reply With Quote
Old 10-28-2014, 08:30 AM   #6
nick61416
Thank you for that info. That is was I assumed I would need to do i just wanted to make sure.
Accelerated Industries (Auto HVAC install and wiring kit) iketiak User/Vendor/Sponsor Reviews, Feedback, Comments 1 08-13-2015 10:27 PM
Spec D headlight HID Install instructions/wiring? jibai Cosmetic Modification (Interior/Exterior/Lighting) 9 04-05-2015 02:38 PM
Help with Wiring/Amp Install Jigglybus Electronics | Audio | NAV | Infotainment 5 07-15-2014 11:27 PM
Amp wiring help + 3d printed tablet mount transition Electronics | Audio | NAV | Infotainment 9 03-04-2014 08:41 PM
Anyone manage to succesfuly install the DDM HID wiring harness in their car? wawro569 Cosmetic Modification (Interior/Exterior/Lighting) 5 09-25-2012 11:02 PM
