Old 10-25-2014, 11:22 PM   #1
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
Lightweight wheels in 18x8.5?
Lightweight to me is starting at 18lbs a wheel and go down.
WallsAndFoundations is offline   Reply With Quote
Old 10-26-2014, 02:50 PM   #2
37
degrees
37's Avatar
Drives: 6MT BRZ
TWS T-66F (86/BRZ spec)
18x8.5 5x100 +42 56.1mm bore
6.90 kg (15.21 lbs)
http://www.tws-forged.com/tws_t66-f.html
Volk Racing CE28N
18x8.5 5x100 +44 65mm bore (needs hub-centric rings)
~7.30kg (~16.00 lbs)
http://www.rayswheels.co.jp/products...&wheel=CE28N10
Volk Racing ZE40
18x8.5 5x100 +45 65mm bore (needs hub-centric rings)
http://www.rayswheels.co.jp/products...=ja&wheel=ZE40
Advan Racing RSII
18x8.5 5x100 +45 73mm bore (needs hub-centric rings)
~7.90kg (17.40 lbs)
http://www.yokohamawheel.jp/brand/ad...index_jpn.html
SSR GTF01
~8.0 kg (17.6 lbs)
http://www.ssr-wheels.com/wheels/gtf01.asp
SSR Type F
~8.0 kg (17.6 lbs)
http://www.ssr-wheels.com/wheels/typef_1516171819.asp
37 is offline   Reply With Quote
Old 10-26-2014, 03:02 PM   #3
WallsAndFoundations
Drives:
6.90 kg (15.21 lbs)
Volk Racing CE28N
Volk Racing ZE40
SSR GTF01
~8.0 kg (~17.6 lbs)
No surprise half of those are by Volk. Man though I wish they looked a little bit better though. Thanks man!
Old 10-26-2014, 03:07 PM   #4
37
degrees
37's Avatar
Drives: 6MT BRZ
I'm still editing the list. Don't expect anything cheap.
Sub-18lbs is difficult without going with the standard RPF1 in an 18x8.0 +35 (which I believe is right at 18lbs).
The question comes down to needs, budget and whether or not you can afford to potentially damage a hard-to-get, lightweight, forged, expensive wheel on the street. If it's for track-only use then a 17x9 RPF1 is a much better investment.
Old 10-26-2014, 03:10 PM   #5
WallsAndFoundations
Drives:
You the man! I expect them to be 600-1000 a wheel... willing to go as high as 800 a wheel if the gains are good enough.
Old 10-26-2014, 03:17 PM   #6
37
degrees
37's Avatar
Drives: 6MT BRZ
TWS are the lightest in the $800 range. @CSG Mike should be able to set you up.
http://counterspacegarage.com/produc...orged.html?p=1
Old 10-26-2014, 03:19 PM   #7
WallsAndFoundations
Drives:
I like the design but are there any more concave styles?
Old 10-26-2014, 03:23 PM   #8
37
degrees
37's Avatar
Drives: 6MT BRZ
You won't see concave without going 9.5" wide and +35 offset. Staying under 18lbs in those dimensions isn't easy. If concave looks are important then you might as well kiss an 8.5" wheel goodbye.
TWS are functional wheels intended for the lightest weight possible in a given size. Their offsets are high to keep the wheel tucked under the fender and minimize crap thrown back on the car.
Old 10-26-2014, 03:24 PM   #9
WallsAndFoundations
Drives:
I'd imagine going that wide will add about 2 pounds a wheel too, huh? Haha shit man..
Old 10-26-2014, 03:30 PM   #10
gramicci101
Off Topic
There's also the Enkei RS05RR. 18x8.5 is a hair over 18 lbs. It has a front face though. The 18x9.5 has a middle face, but if you want a rear face (most concave), you'll need at least an 18x10, which doesn't come in 5x100.
Old 10-26-2014, 03:32 PM   #11
WallsAndFoundations
Drives:
I was looking at those. They actually look really sweet, I like them. Do you have any pics of 18x8.5 specifically? Google images has a little bit of everything. .
Old 10-26-2014, 03:41 PM   #12
gramicci101
Off Topic
The ones that look so sweet and super concave on the stanced out rocket bunnies are probably 18x10 and 18x11 with rear faces and deep offsets. Sigh.
Here's a thread with 18x8.5+42 (front face). Still looks pretty nice.
edit: For some reason the link takes you to the middle of the page. Scroll to the top for pics.
Old 10-26-2014, 04:02 PM   #13
WallsAndFoundations
Drives:
Wish the car had more power to run setups like that? I wanna go with wheels like that but it's not gonna happen with an NA setup... I might go with the enkeis, but honestly the te37sl has been the wheel I've been eying. Can't find any other wheel that matches what I like.. stupid hard to find complementing wheels.
Old 10-26-2014, 04:19 PM   #14
fatoni
what kind of gains do you expect by getting slightly lighter wheels?
Drive upgrades. Don't buy them.
Lightweight Wheels - Does it really matter? cdo221 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 64 11-23-2023 07:07 AM
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 06:32 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
Lightweight 17x9 wheels? Thongpocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-27-2014 11:43 PM
Lightweight wheels or wide wheels Moetivegt86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 11-06-2013 10:57 PM
