| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives:
Lightweight wheels in 18x8.5?
Lightweight to me is starting at 18lbs a wheel and go down.
#2 |
degrees
Drives: 6MT BRZ
TWS T-66F (86/BRZ spec)
18x8.5 5x100 +42 56.1mm bore 6.90 kg (15.21 lbs) http://www.tws-forged.com/tws_t66-f.html Volk Racing CE28N 18x8.5 5x100 +44 65mm bore (needs hub-centric rings) ~7.30kg (~16.00 lbs) http://www.rayswheels.co.jp/products...&wheel=CE28N10 Volk Racing ZE40 18x8.5 5x100 +45 65mm bore (needs hub-centric rings) ~7.30kg (~16.00 lbs) http://www.rayswheels.co.jp/products...=ja&wheel=ZE40 Advan Racing RSII 18x8.5 5x100 +45 73mm bore (needs hub-centric rings) ~7.90kg (17.40 lbs) http://www.yokohamawheel.jp/brand/ad...index_jpn.html SSR GTF01 18x8.5 5x100 +45 73mm bore (needs hub-centric rings) ~8.0 kg (17.6 lbs) http://www.ssr-wheels.com/wheels/gtf01.asp SSR Type F 18x8.5 5x100 +45 73mm bore (needs hub-centric rings) ~8.0 kg (17.6 lbs) http://www.ssr-wheels.com/wheels/typef_1516171819.asp Last edited by 37; 10-26-2014 at 03:05 PM. |
| The Following 2 Users Say Thank You to 37 For This Useful Post: | SkAsphalt (10-27-2014), WallsAndFoundations (10-26-2014) |
#3 | |
Drives:
#4 |
degrees
Drives: 6MT BRZ
I'm still editing the list. Don't expect anything cheap.
![]() Sub-18lbs is difficult without going with the standard RPF1 in an 18x8.0 +35 (which I believe is right at 18lbs). The question comes down to needs, budget and whether or not you can afford to potentially damage a hard-to-get, lightweight, forged, expensive wheel on the street. If it's for track-only use then a 17x9 RPF1 is a much better investment. |
| The Following 3 Users Say Thank You to 37 For This Useful Post: |
#5 |
Drives:
You the man! I expect them to be 600-1000 a wheel... willing to go as high as 800 a wheel if the gains are good enough.
#6 |
degrees
Drives: 6MT BRZ
TWS are the lightest in the $800 range. @CSG Mike should be able to set you up.
http://counterspacegarage.com/produc...orged.html?p=1 |
| The Following 2 Users Say Thank You to 37 For This Useful Post: | CSG Mike (10-27-2014), WallsAndFoundations (10-26-2014) |
#7 | |
Drives:
#8 |
degrees
Drives: 6MT BRZ
You won't see concave without going 9.5" wide and +35 offset. Staying under 18lbs in those dimensions isn't easy. If concave looks are important then you might as well kiss an 8.5" wheel goodbye.
TWS are functional wheels intended for the lightest weight possible in a given size. Their offsets are high to keep the wheel tucked under the fender and minimize crap thrown back on the car. |
#9 |
Drives:
I'd imagine going that wide will add about 2 pounds a wheel too, huh? Haha shit man..
#10 |
Off Topic
There's also the Enkei RS05RR. 18x8.5 is a hair over 18 lbs. It has a front face though. The 18x9.5 has a middle face, but if you want a rear face (most concave), you'll need at least an 18x10, which doesn't come in 5x100.
#11 |
Drives:
I was looking at those. They actually look really sweet, I like them. Do you have any pics of 18x8.5 specifically? Google images has a little bit of everything. .
#12 | |
Off Topic
Here's a thread with 18x8.5+42 (front face). Still looks pretty nice. edit: For some reason the link takes you to the middle of the page. Scroll to the top for pics. |
| The Following User Says Thank You to gramicci101 For This Useful Post: | WallsAndFoundations (10-26-2014) |
#13 | |
Drives:
#14 |
what kind of gains do you expect by getting slightly lighter wheels?
Drive upgrades. Don't buy them.
| Lightweight Wheels - Does it really matter? | cdo221 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 64 | 11-23-2023 07:07 AM |
| BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" | GuerillaRacing | Wheels and Tires | 116 | 01-20-2015 06:32 PM |
| TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance | Jason@DSG | Wheels and Tires | 37 | 12-17-2014 02:50 PM |
| Lightweight 17x9 wheels? | Thongpocket | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 02-27-2014 11:43 PM |
| Lightweight wheels or wide wheels | Moetivegt86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 11-06-2013 10:57 PM |
