CANADA Canada
Old 10-23-2014, 05:26 PM   #1
oppiee
Drives: 2014 Scion FRS (Red)
Hard acceleration/revving noise
Hey guys,
I noticed that if my car is in neutral and stopped if I hit the accelerator hard say from 0% to 60%, I hear the scratchy sandy noise just before the rev.
I hear it at times to when I do somethign similar while on the road. not sure if you guys have similar experience or that I should get it looked at.
Thanks
oppiee is offline   Reply With Quote
Old 10-23-2014, 06:08 PM   #2
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Search "tip-in knock". Post if that sounds like it.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 10-23-2014, 09:12 PM   #3
wparsons
wparsons's Avatar
I doubt it's tip in knock, it's probably the suction noise from the intake side of the engine. It's more pronounced with an aftermarket intake, but 100% stock it's definitely more noticeable on these cars than most other cars I've driven.
flickr
Old 10-23-2014, 09:27 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's a cool sound, like when you pull out that wad of paper clogging the shop vac.
Big fucking throttle body and a fast servo.
Old 10-24-2014, 12:46 AM   #5
oppiee
It kind of sounds like tip-in knock, but only happens on the initial acceleration. It doesnt always happen. It happens when I blip the throttle for a rev match too. funny thing is it doesnt always happen.
Its not the intake noise for sure.
Old 10-24-2014, 05:25 PM   #6
nocwage
MMTT
Drives: 2019 Subaru BRZ
Could be the stepper motor moving the throttle plate?
nocwage is offline   Reply With Quote
Old 10-26-2014, 11:58 AM   #7
PMPB
Drives: BRZ Sport-tech
I'm with wparsons on this one...
Under the right conditions this car sometimes creates weird intake noises. I have a plug in my 'sound tube', but occasionally, under the right conditions, I can the pressure waves pushing past the plug.
OP, do you have a plug in your sound tube? Try either putting one in, or removing it, to eliminate that as source of bizarre intake sounds.
PMPB is offline   Reply With Quote
Old 10-26-2014, 12:02 PM   #8
oppiee
I did have a plug in before. I took it out.
With the plug in for some reason at high revs i kept hearing this rattle, but its gone with the plug out. So i left it out.
So this sound is with the plug out. Not sure if that helps.
Old 10-26-2014, 01:59 PM   #9
Ultramaroon
not playing cards
Here's a crazy thought. What would a failed/failing kazoo thingy sound like? It could happen, right?
But I'm gonna stick with my original because I hear it all the time. At least it still sounds like a car with a real throttle cable.
Slow Revving / Acceleration after TSB 0040-13 Hardway Issues | Warranty | Recalls / TSB 9 08-25-2014 10:14 AM
Rattling Noise on acceleration Naughty AFRICA 2 05-14-2013 11:17 AM
Engine noise free revving or under load heeltoe86 Issues | Warranty | Recalls / TSB 4 04-29-2013 12:58 AM
Does the A/C cut off upon hard acceleration? brillo Scion FR-S / Toyota 86 GT86 General Forum 13 03-26-2013 09:31 AM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
