CANADA Canada
Old 10-23-2014, 04:10 PM   #1
BRZ'13
BRZ'13's Avatar
Drives: subaru
boosted/supercharged frs/brz
BRZ'13 is offline   Reply With Quote
Old 11-07-2014, 01:47 PM   #2
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
Why would it cost you $10,000?
Aren't most supercharger/turbo kits 4-6k?
wutsaiu is offline   Reply With Quote
Old 11-07-2014, 02:56 PM   #3
wparsons
wparsons's Avatar
Plus install, plus tuning, plus supporting mods, etc.
flickr
Old 11-07-2014, 03:13 PM   #4
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I did my own install and it cost me over 8,000$ Ecutek and dyno tune alone was almost 2,000. Then gauges, radiator, oil cooler, zip ties, hose clamps, oil, clutch, fuel pump, injectors......transmission.
The Following User Says Thank You to Reaper For This Useful Post:
hmong337 (11-07-2014)
Old 11-07-2014, 03:21 PM   #5
Reaper
Reaper's Avatar
Drives: violent
The car is fun and quick at 300whp and very well matched. I think guys are doing high 12 second quarters if that gives you an idea. With e85 you can turn it up into the 400+whp range and it becomes a low low 11 second car and will be in the same straight line highway pull feeling as a gtr, corvette etc. At 450whp I'm not nervous around any stock non exotic car so far and spin 3rd all day, 4th when the tires are cold. At 500whp it becomes difficult to drive and does 7 second 60-130s and you buy transmissions and tires monthly.
How I looked at it when I decided how much power I wanted was I took the HP to weight ratio of other fast cars I had driven and came up with how much power and weight reduction my frs needed to feel like that.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
hmong337 (11-07-2014), misooscar (11-07-2014)
Old 11-07-2014, 06:32 PM   #6
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Originally Posted by BRZ'13 View Post
Honestly 10k is on the low side of things to. I would rather spend the money then take short cuts thats why I'm stuck between boost or v8. By the time I build the block to run higher boost (no e85 here) it will cost 15k if not more.
This is the delimma I am in too. A fully built and boosted fa20 with all the fixin's is into about $15k. That's in the ballpark of how much an LS2 swap should cost.
hmong337 is offline   Reply With Quote
Old 11-07-2014, 08:00 PM   #7
wutsaiu
wutsaiu's Avatar
It really depends on how much power you want.
If you wanted a little bump on power I'm sure for example an innovate supercharger kit and simple tune wouldn't cost anywhere near 10k. I think it is pretty clear now that you want much more than that. There is of course no end to the amount of money one can spend on cars. I'm glad I brought life to this thread. If you do decide to do an LS swap I hope you post something about it.
Old 11-07-2014, 11:15 PM   #8
wutsaiu
wutsaiu's Avatar
There will be lots of people who say not to do engine swap but if you're happy with the price and trust the shop will do a good job then I see no reason not to go that route. I'm assuming the shop will get all the electronics like the stock tach working properly?
Old 11-08-2014, 08:41 AM   #9
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
NV auto is good ppls, they should be able to do it right!
I want a ride if you go LS
mkivalex is offline   Reply With Quote
Old 11-10-2014, 03:52 PM   #10
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I've riden in a few within the 250-270 whp range and honestly with how light these cars are I don't think I'd ever need or want more to be honest. It's easy for things to get crazy past that power to weight ratio.
Old 11-10-2014, 05:44 PM   #11
86pro
Drives: frs
I have no problems driving my car on the street, these motors are worth modifying. If done right you will always smiling. At 300whp the average skilled driver will still have confidence to drive it but at 450 upwards it takes abit of skill to control.
86pro is offline   Reply With Quote
Old 11-10-2014, 06:35 PM   #12
wbradley
Sarcastic SOB
wbradley's Avatar
I wonder how you get the power to the pavement when going 300+ HP. Mandatory Rocket Bunny with 10" W wheels? Traction control light continuously flashing? This isn't a 911 Turbo, it really wasn't made for that power in its current form IMHO.
Old 11-10-2014, 06:36 PM   #13
Reaper
Reaper's Avatar
Drives: violent
Progressive boost per gear with an ebcs and ecutek. 255 PSS' s help.
Old 11-10-2014, 08:11 PM   #14
wbradley
Sarcastic SOB
wbradley's Avatar
Yeah but the 911 has a lot of weight directly over the rear wheels to assist traction. It just seems to me there are less costly and more engineered options for small high power RWD cars. Mind you none of them will necessarily have the originality. A used 911 turbo would be less risky.
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
My Boosted BRZ protpibe Member's Car Journals 84 09-22-2014 03:26 PM
Boosted BRZ mike the snake Member's Car Journals 3 12-28-2013 11:11 AM
RIP Boosted BRZ & Driver ft_sjo BRZ First-Gen (2012+) — General Topics 103 11-17-2013 10:07 PM
AU Boosted club nix AUSTRALIA 18 01-19-2013 12:50 AM
