Old 10-18-2014, 09:50 PM   #1
cslntuee
Drives: Subaru BRZ Limited
Brembo STI Brake for BRZ
I found one vendor sell the whole set Brembo STI Brake(front and rear) for BRZ which do not need any additional modify.
However, this vendor is in Australia.
http://www.prospeedracing.com.au/pro...-T3-Rotor.html
Is there any seller in US sell the same complete kits?
Thanks.
cslntuee is offline   Reply With Quote
Old 10-18-2014, 10:04 PM   #2
wparsons
wparsons's Avatar
Waste of time/money IMO. The stock calipers have plenty of clamping power for stock sized rotors. If you need more thermal capacity for heavy track use, you'll need a full BBK.
flickr
Old 10-19-2014, 01:31 AM   #3
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
I don't know what the currency transfer rate is, but I just put together the same package, with stainless lines as well, for $1800usd. That's ebay for the calipers and rallysport for the rest. They are great brakes, but that is far too expensive.
The Racers Line is offline   Reply With Quote
Old 10-19-2014, 04:26 PM   #4
cslntuee
Could you provide the caliper link from Ebay?
Thanks.
Old 10-19-2014, 04:30 PM   #5
The Racers Line
Thanks.
I don't have the link anymore because I bought them, but just searching "STi brembos" or "STi calipers" will give results. I don't see any 08+ black calipers on their now. But they do pop up.
The Following User Says Thank You to The Racers Line For This Useful Post:
cslntuee (10-21-2014)
Old 10-19-2014, 04:33 PM   #6
cslntuee
I hear some people said that you will feel the power becoming weaker
after upgrade to 18 inch wheel.
Is that true?
Thanks.
Old 10-19-2014, 04:45 PM   #7
cslntuee
Is that same as this one?
https://www.subarugenuineparts.com/p...roducts_id=914
https://www.subarugenuineparts.com/p...oducts_id=1291
Thanks.
Old 10-19-2014, 05:12 PM   #8
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
Good tires, stainless brake lines, fluid, and pads will net you some awesome stopping power. And you'll have spent less than on the brembos.
VacantSky is offline   Reply With Quote
The Following User Says Thank You to VacantSky For This Useful Post:
cslntuee (10-19-2014)
Old 10-19-2014, 05:22 PM   #9
wparsons
wparsons's Avatar
Is that true?
Thanks.
See below...
You don't even need the stainless lines, they don't help with braking power or stopping distances. They do improve pedal feel, but that's it.
Better pads and fluid is all you need to significantly improve the stock brakes.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 10-19-2014, 05:38 PM   #10
The Racers Line
No, those came on the WRX. They will fit, however, I don't know if they are much of an upgrade.
Old 10-19-2014, 06:39 PM   #11
gramicci101
Off Topic
WRX 4 pot fronts are an upgrade. WRX 2 pot rears are a downgrade.
OP, the OEM brakes are more than powerful enough to engage the ABS. The absolute easiest upgrade to your brakes will be better tires. If you still want more after that, new pads and fluid and maybe brake ducts. If you're going to the track every other weekend and you're fading or glazing your pads after 20 minutes, then get a BBK. The AP Sprint is particularly well regarded by the track drivers here.
If you want bigger, more awesome-looking brakes to fill your 18" wheels at a car show, Stoptech makes 355mm front / 345mm rears that will do the job.
The Following 4 Users Say Thank You to gramicci101 For This Useful Post:
cslntuee (10-19-2014), DylanJZA (05-08-2023), The Racers Line (10-19-2014), wparsons (10-20-2014)
Old 10-19-2014, 07:36 PM   #12
VacantSky
The Angry Brit
VacantSky's Avatar
The wrx 4 pots send the bias rearwards, so they kind of are a downgrade. The 30mm nissan 4 pot (same piston size as the wrx caliper but with different mounting pattern) with the KNS adaptor allows you to use a larger rotor (legacy gt) which nets you an unnoticeable 1% forward bias. As well as better thermal capacity with the bigger rotors and the pedal feel of a fixed caliper. You can pick up the nissan 4 pots, adaptors, pads, rotors, and some stainless lines all new (calipers reconditioned) for maybe $50 more than new wrx 4 pots alone
Old 10-19-2014, 07:39 PM   #13
VacantSky
The Angry Brit
VacantSky's Avatar
See below...
I understand that, but if your looking to improve your brakes by upgrading pads and fluid then adding stainless lines just make sense.
Old 10-20-2014, 01:44 AM   #14
Poodles
Drives: 2015 Series.Blue
Except both TRD and STI have pulled their stainless brake lines because of some issues with them...
Brembo Brake Install in Denver Parikh1234 Rocky Mountains / Great Plains 4 07-23-2014 04:06 PM
Brembo Big Brake Kits ON SALE!! MVP Motorsports RobertatMVP Brakes, Suspension, Chassis 25 07-11-2014 01:49 PM
Brembo 6pot front, 4pot rear Big Brake Kit v1ru5 Brakes, Suspension, Chassis 6 06-21-2014 04:35 AM
