Old 10-18-2014, 07:16 PM   #1
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Just drove my new BRZ home... on the wrong octane.
So I just drove my new BRZ off the lot. The salesman filled it up with a tank of gas (it was only at 1/4 tank.) I know for a fact that he put 89 octane in it. I then drove it 90 minutes home. I'm now reading the owner's manual and it says never to use less than 91, and there are lots of posts on the forums about how 89 will cause damage.
This is a brand new car (had less than 10 miles on it.) Is 89 octane "safe" in the sense that you just don't want to do it long term, but that the car will just adjust timing and run poorly until I use up this tank, or are there larger forces at play here and should I be doing something else...? Will it cause even MORE problems due to the fact that I'm breaking the engine in with the wrong octane? I'm really hoping it's one of those things that's really not a big deal and that I shouldn't worry about causing damage.
Stang70Fastback is offline   Reply With Quote
Old 10-18-2014, 07:52 PM   #2
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
From my prior experiences and past vehicles, I've also found out that many dealers put less than what's recommended, and that's why I've specifically written on paper of 'no fuel up' for my ordered BRZ. It doesn't make much of a difference however I'm just very OCD.
You should be just fine, I'm sure. As others would mention, go ahead and follow the break-in process and burn the fuel as you normally would so that you can focus on your next fuel up with the correct octane.
No worries, partner.
Texas BRZ is offline   Reply With Quote
Old 10-18-2014, 07:54 PM   #3
raven1231
Yes, no worries at all.
Old 10-18-2014, 08:08 PM   #4
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
You'll be fine. Just get some 91 in there asap
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 10-18-2014, 08:21 PM   #5
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
Oh no! That's all bad!!!
ITS TOTALED
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
The Following 6 Users Say Thank You to Rapiddan45 For This Useful Post:
@Art_Mighty (10-19-2014), covance (10-30-2014), DriftinFRS (10-20-2014), iStanley (10-19-2014), MrBlaze-65 (10-23-2014), Pseud0logik (10-25-2014)
Old 10-18-2014, 08:33 PM   #6
My dealer did the same and then argued with me when I said minimum 91. They thought that 91 was only recommended. Showed them the manual and they were rather embarrassed.
Not a huge problem as the ECM will adjust for it for the short time the tank will last.
tigermack (10-20-2014)
Old 10-18-2014, 08:38 PM   #7
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
And then you posted, in the WRONG FORUM... No BRZ's allowed in here lol just pulling your leg.
But really you'll be fine! You were (hopefully) driving her easy as she is new. The car is factory tuned for 91, and that's how it will perform best, and make it's best power figures. On 89 you'll see poor power and poor fuel economy. Just fill up with premium min 91 and you'll be fine.
VacantSky is offline   Reply With Quote
Old 10-18-2014, 08:52 PM   #8
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
ITS TOTALED
post like this should be automatically deleted.
86-tundra is offline   Reply With Quote
The Following 2 Users Say Thank You to 86-tundra For This Useful Post:
gt8613 (10-31-2014), Rapiddan45 (10-18-2014)
Old 10-18-2014, 08:53 PM   #9
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
it'll be fine, go out and enjoy your new brz!!
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 10-18-2014, 08:55 PM   #10
Stang70Fastback
A.K.A. Starlord
Thanks guys. Yeah I realized this was in the wrong forum when I couldn't find it after I posted, lol. I'm definitely following the recommended break-in procedure (under 4k, no heavy throttle) so I haven't ragged on it at all. I kind of figured it was probably okay. I texted the sames guy and he said he asked their mechanic and the mechanic said 89 is fine, lol.
Old 10-18-2014, 09:05 PM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
There's a knock detection sensor that will make the ECU pull timing until you refuel with 91 or better. Most likely as previously stated, mileage and power will be marginally reduced but absolutely no harm will be done. The person who fueled up is a moron. And sadly it could have been the sales rep. They sometimes know the least as this doesn't deter their overall ability to close deals.
Old 10-18-2014, 09:08 PM   #12
mid_life_crisis
Drives: FR-S 10 #103 AT
As soon as there is any room in the tank start putting in the highest octane available. They'll average out.
Old 10-18-2014, 09:10 PM   #13
Stang70Fastback
A.K.A. Starlord
I'm going to wait till it gets to half and then put 93 in it. That should bring it to 91! :P
And 93 from here on out!
Old 10-19-2014, 02:25 AM   #14
iStanley
They call me Stan
iStanley's Avatar
Drives: Firestorm FR-S
You shouldn't be so salty and learn to take a joke.
iStanley is offline   Reply With Quote
The Following 4 Users Say Thank You to iStanley For This Useful Post:
covance (10-30-2014), DriftinFRS (10-20-2014), MrBlaze-65 (10-23-2014), Tcoat (10-19-2014)
What's wrong with this car? Suberman CANADA 41 01-14-2014 12:35 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
What's wrong with my HID kit? seven Cosmetic Modification (Interior/Exterior/Lighting) 17 11-28-2012 07:36 PM
