Old 10-14-2014, 03:18 PM   #1
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
-50mm on a Rocket Bunny.
This may be the wrong forum for this question, feel free to move it if so.
I am building a RBv1 GT86 and have a set of Ohlins coil overs for the car. I have noted that the Ohlins kits go a max of -50mm on ride height. Is this enough for a good look. Obviously, I'm more interested in ultimate handling than a stances look, but I also don't want to build a skyscraper lol.
Pictures would be nice if poss please.
Nigelr32 is offline   Reply With Quote
Old 10-14-2014, 03:24 PM   #2
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
for handling most people dont go below -25mm or so. you start screwing with the roll centers and other fancy things when you go lower.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 10-14-2014, 03:31 PM   #3
Nigelr32
Oh?? Thanks for that. Looks like I may have to play with suspension mounting points then? I assume -25mm on a RB would "look" pants?
My car WILL handle and it WILL be a RB. I am absolutely smitten with the look of the kit.
Old 10-15-2014, 10:29 AM   #4
Roadcone
StreetKart
honestly if you've got the cash to do it correctly it shouldnt be anything to spend a few more grand having the body shop make everything exactly like you want.
Old 10-15-2014, 03:06 PM   #5
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
You do realize you have to cut massive amounts of sheet metal out for Rocket Bunny? You shouldn't have any problem slamming your car if that's what you want. I'm running 325/645-18s and while I don't set my ride height low we most certainly compress the suspension under race conditions way more than that.
Also here's a picture of how much we ended up cutting out of the fenders.
How much you cut out will ultimately determine how low you can go. I would make sure you work with the body shop or whoever is installing the RB kit so they can cut out and then seal what you need to clear your wheel/tire/ride height combo.
Element Tuning is offline   Reply With Quote
Old 12-26-2014, 11:12 AM   #6
Nigelr32
Thanks for your reply Phil, I am aware I need to cut out lots of steel for the kit to fit which I will be doing myself. I am a time served engineer from Rolls Royce Aerospace and have many hours experience of fabrication, welding, composites and painting.
Right now, the body is on hold as I decided to build a Turbo Motor first. I'm loving your posts here on the FA 20.
Old 12-27-2014, 12:38 PM   #7
xwd
What offset rims are people running with the RB kit? I'm looking at potentially running something like 17x12 or 18x12 but no idea what office to use.
Old 02-08-2015, 11:46 AM   #8
BRZR1
Drives: v8 BRZ
answers?
BRZR1 is offline   Reply With Quote
Old 02-11-2015, 05:35 AM   #9
TekPrime
Chef
TekPrime's Avatar
Drives: 2014 Subaru BRZ Limited (D6X)
For good looks I would say try to get as much negative offset as avaliable I went - 18 front an - 38 rear. Max rim width I believe is 9.5 front and 11 rear
TekPrime is offline   Reply With Quote
Old 02-15-2015, 01:35 PM   #10
BRZR1
Drives: v8 BRZ
what about tires... I'm hoping to run a 26" tire that actualy fits the rim, say 295 rear 265 fronts?
Rocket bunny style DRL without the rocket bunny kit. ducky369 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-22-2014 06:38 PM
Rocket Bunny Kit ??? Cosmetic Modification (Interior/Exterior/Lighting) 29 04-01-2014 05:21 AM
Rocket Bunny kit (just lip) encity5 Cosmetic Modification (Interior/Exterior/Lighting) 8 11-01-2013 10:01 PM
Rocket Bunny ver.2 kit SnapOv3st3r FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 08-19-2013 07:29 PM
WTB Rocket Bunny kit Yamajee Exterior Parts (Aero, Lighting, Etc.) 5 05-21-2013 09:23 AM
