Old 10-10-2014, 03:06 PM   #1
frs10
Drives: tezla
window off tract?
my window is making a strange sound and was wondering if anyone knows how to check if the window is off the track without taking the door apart? is anyone else having this issue?
frs10 is offline   Reply With Quote
Old 10-10-2014, 03:33 PM   #2
strat61caster
strat61caster's Avatar
My windows make a sound similar to the 4th bar in "In the Hall of the Mountain King" I am told this is normal, what kind of sounds are your windows making?
Old 10-10-2014, 03:55 PM   #3
frs10
Drives: tezla
the same sound it makes when you open or close the door and the window goes up/down except really loud with a ehhh noise
Old 10-10-2014, 04:43 PM   #4
strat61caster
Welp sounds like a trip to the dealership then. Without a video pretty much what your saying is that 'my window is loud' which means that something would be making a noise it shouldn't which means replacement.
Not much better advice to be found here unless you can offer more details, best of luck.
Old 10-10-2014, 05:04 PM   #5
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
mine makes a loud clack noise when it goes up or down when you open the door. it doesn't do it all the time but i'd say 75%. I need to find some rubber treatment stuff and see if that helps.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 10-12-2014, 03:03 PM   #6
frs10
Drives: tezla
ill try to see if i can get that noise in a clip or something later
Old 10-15-2014, 04:24 PM   #7
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
For me, both driver and passenger windows make a clack noise when rolling down (with window fully up and door closed), and it does it almost exclusively when the car has been sitting outside in the sun/heat. I am planning to take the door panel off and do an inspection. I suspect there may be loose screws in the window 'drivetrain' somewhere. Will post pix and findings when able.
PWBRZ is offline   Reply With Quote
Old 10-15-2014, 04:48 PM   #8
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
My windows screech when they go up and down. Bringing my car to the dealer soon to get a whole handful of quirks fixed. I've seen another thread for this too.
Ill let you know what the dealer says and see if I can find out why and how it happens.
GotBRZ1691 is offline   Reply With Quote
Old 10-15-2014, 10:23 PM   #9
Mikem53
Drives: FR-S 6MT
Save a trip to the dealer and all the associated headaches..
Get a tube of Honda Genuine Shin-Etsu Grease. Problem solved
and weatherstrip will stay flexible and not dry out.
Can order it through the dealer or Amazon.. the stuff is best of breed
and will last for years as a little bit goes a long way..
Mikem53 is offline   Reply With Quote
Old 10-15-2014, 10:26 PM   #10
Mikem53
Drives: FR-S 6MT
Glass is sticking to the weatherstrip and not dropping in time as the door is opened. Needs some lube on the weather seal. See above note.
Old 10-15-2014, 10:34 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
Guys, I'm in the middle of writing a DIY to fix exactly this. Compare your good window to your bad. Does the bad one seem to twist a little at the end of its travel? Mine would go up and the top would rotate to the rear as it seated.
It was causing the regulator to bind. Sloppy assembly work at the factory. I thought I would have to open up a slot until I removed the nut and found a factory adjustment slot already there. I'll try to get the DIY finished before this weekend.
Before & After clips. It's really subtle.
[ame]http://youtu.be/H1daWc_5z7k[/ame]
[ame]http://youtu.be/RVahTymv2T4[/ame]
Old 10-16-2014, 10:11 AM   #12
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i barely cant see difference!
Old 10-16-2014, 10:46 AM   #13
RobertPaulson
Drives: 2017 Golf R
yes i have noticed mine doing that at times. i'll keep an eye out for your DIY.
Old 10-17-2014, 12:31 AM   #14
tinma
Drives: '13 BRZ
subbed for DIY
tinma is offline   Reply With Quote
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 07:25 AM
Window Air Leak After Frozen Window TSB Fix Luckrider Issues | Warranty | Recalls / TSB 6 04-27-2014 06:24 AM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 05:34 AM
Stock intake tract flow testing? zooki Engine, Exhaust, Transmission 1 01-24-2013 10:34 PM
