Old 10-10-2014, 07:32 AM   #1
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Unhealthy-sounding metallic rasp at 4K
Earlier this year, I upgraded to the following mods:
Perrin 2.5" resonated catback
Custom catted front pipe
Custom over pipe
Perrin CAI
Sounded great, happy with it.
Two months later, I got an ECUTEK tune. After that, I would get a very nasty, unhealthy metallic rasp around 4000 RPM.
Have no idea what is except it happened after the tune? Is it possible this was caused
by the tune???
It only happens when you apply hard throttle (it's fine when being gentle), and it only happens when the car is in gear (could not replicate the sound when revving in neutral).
Any help would be awesome.
white_knight is offline   Reply With Quote
Old 10-10-2014, 07:36 AM   #2
WNDSRFR
Drives: FR-S,GTI
Don't worry about it. The OFT tune does the same thing. Something to do with VVT harmonics or something. It's been discussed previously in the tuning section I believe.
Old 10-10-2014, 07:37 AM   #3
Shady195
Drives: '13 10 Series FRS #1203
Custom over pipe
Perrin CAI
by the tune???
White, that rasp you are hearing is caused by the aggressive change in the VVT to help with the torque dip many tuners apply..
It's nothing to be concerned about. It can be heard on the stock tune as well however its less aggressive.
Shady195 is offline   Reply With Quote
Old 10-10-2014, 07:41 AM   #4
white_knight
Ok that makes me feel a bit better. I was concerned the piping might be faulty. However, I do have a friend with an almost identical setup, but no rasp. Explain that?!
I'm putting in the SpeedFactory UEL headers in next week -- is this going to make it worse?
Old 10-10-2014, 07:45 AM   #5
Shady195
He is tuned as well?
Define almost identical?
A different intake as in your case could definitely make it more audible. Does he have a tune? Is it from the same tuner? His VVT timing may not be as aggressive.
If you're that concerned talk to your tuner, however that "sound" is quite normal on tuned cars, it all depends on how aggressive the tune is.
Old 10-10-2014, 07:51 AM   #6
white_knight
Same tuner and CBE. Different FP and intake. Plus he had RevWorks headers. I'm guessing the headers would make for a less aggressive tune?
Old 10-10-2014, 09:12 AM   #7
Shady195
I know in the case of the OFT and a few other remarks, yes the VVT change is less aggressive with a tune including a header.
Old 10-11-2014, 03:33 AM   #8
Cal3000
Drives: Panda FR-S
I have the same noise. The noise came in after about 14k miles after I got a dyno tune.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 10-11-2014, 09:50 AM   #9
wparsons
wparsons's Avatar
The resonance will be less noticeable if you have a header since the tune will likely be less aggressive in trying to tune out the torque dip. There's nothing dangerous about it, and there are a couple threads in the tuning section about it.
I had the noise on the stock tune as well, it's just more pronounced with an aftermarket tune.
flickr
Old 10-11-2014, 10:33 AM   #10
J.C.
Drives: '13 Raven FR-S
Make sure the piping after the midpipe isn't hitting the diff. Might want to check any v-band clamps and other flange connections too.
J.C. is offline   Reply With Quote
Old 10-11-2014, 12:07 PM   #11
Dezoris
Dezoris's Avatar
I made a big stink about it with my tuning. And had Perrin strip the VVT "optimaztion" out and sound was gone. No one can prove if its bad long term or not or why the systen makes the noise. Some people with the same tune dont have the noise because after the flash process the VVT/cam calibration does not finish as they drive off right after.
I tried that a few times to see and it randomly made no noise.
Old 10-11-2014, 09:50 PM   #12
wparsons
wparsons's Avatar
I've heard the sound enough on mine with the stock tune to not even think twice about it anymore.
It's not a metallic clangining, it is most definitely just resonance/rasp. It doesn't always happen in a given RPM range, it has to be under certain circumstances. It also happens for sure a small window that it's definitely a resonance.
flickr
Best Sounding Exhaust $1k or Less KelvinBRZ Engine, Exhaust, Transmission 7 09-06-2014 02:19 AM
What is the best sounding exhaust for under 2k? WallsAndFoundations Engine, Exhaust, Transmission 61 07-23-2014 06:49 PM
Rasp help??? Gshoxx Engine, Exhaust, Transmission 3 05-01-2014 01:20 AM
Best Sounding V6 Engine Wes B. Other Vehicles & General Automotive Discussions 44 07-01-2013 10:39 AM
BRZ sounding like a Subaru Knightmare BRZ First-Gen (2012+) — General Topics 34 11-18-2012 03:17 AM
