Old 10-09-2014, 07:12 PM   #1
acj47
acj47's Avatar
OBD Fusion app - PID for oil temp?
Is anyone on here using the OBD Fusion app? I'm trying to add the User-Defined PID for Oil Temp as listed here, but not having any luck.
I've attached screenshots of the settings i've tried.
I also changed OBD Mode to "21" and PID Number to "01" with no avail.
Any help would be appreciated, thanks.
acj47 is offline   Reply With Quote
Old 10-10-2014, 01:49 PM   #2
acj47
acj47's Avatar
Update: Figured it out.
"Module/Header" set to "ECM"
"OBD Mode" set to "21"
"PID Number" set to "01"
and to output Fahrenheit, "Equation" set to "((((AC-40)*9)/5)+32)"
The Following User Says Thank You to acj47 For This Useful Post:
Ultramaroon (06-16-2017)
Old 06-16-2017, 03:30 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
I am thrilled that you posted your solution. Many many thanks.
'13 Ford Fusion poormans_LFA Other Vehicles & General Automotive Discussions 41 01-14-2016 07:29 PM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 06:47 PM
What temp are you running at? Shark_Bait88 Scion FR-S / Toyota 86 GT86 General Forum 3 09-02-2014 05:09 PM
Ford Just Unveiled A Fusion That Weighs As Little As A Fiesta dem00n Other Vehicles & General Automotive Discussions 15 06-04-2014 01:25 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-30-2013 12:50 AM
