Old 09-02-2014, 03:27 PM   #1
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
What temp are you running at?
(I'm sure this has been a thread before, but I didn't feel like searching to resurrect a dead thread.)
Anyways, was just out to lunch with a co-worker and we hooked his Torque app up in my car. The car ran at a flat 192°F on the drive back to the office. He said his 328i runs anywhere between 193°-230°F. Simply out of curiosity, have any of you been monitoring operating temps and what are your results?
I'm planning on getting the OBDII plug-in for the Torque app soon, so that I can start monitoring data on my car in much greater detail.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 09-02-2014, 04:49 PM   #2
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
oil or water temp?
I run around 200 F usually for both.
TStafford is offline   Reply With Quote
Old 09-02-2014, 04:51 PM   #3
Shark_Bait88
Originally Posted by TStafford View Post
oil or water temp?
Oil.
Old 09-02-2014, 05:09 PM   #4
stonenewt
Drives: BMW 120d
My BMW's ECU controls the oil & water temps in the car depending on what mode the car is in.
EcoPRO - 115C oil, 108C coolant
Comfort - 100C oil, 95C coolant
Sport(+) - 90C oil & coolant
Once the oil temps are up there my car holds them there within 2C for road driving. The exception to this is in EcoPRO if you start longer pulls at higher power (e.g. climbing a steep hill) it'll reduce the temps, shows the car has a wealth of cooling capacity to call on. A really annoying thing is BMW saw fit to not include an oil or water temp gauge.
The idea is for sports driving you want the most power from & protection for the engine & this occurs at lower oil & water temps. For EcoPRO driving the temps are optimised for lowest internal friction but this will increase engine wear at higher loads so under constant higher loads drops to the comfort temps.
stonenewt is offline   Reply With Quote
The Following User Says Thank You to stonenewt For This Useful Post:
Shark_Bait88 (09-02-2014)
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 04:46 PM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 06:47 PM
Low Temp Thermostat Roadcone Engine, Exhaust, Transmission 21 12-28-2014 08:36 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-30-2013 12:50 AM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 03:57 AM
