Old 10-08-2014, 03:21 AM   #1
amazingbrz
amazingbrz's Avatar
Drives: '14 WRB BRZ Limited
Is my tire gone?
Dont mind my dirty tire but I Just saw this Nasty nail in my tire....
You guys think I can patch this or probably done deal? =/
Newish tire too only like 5k miles too
Sent from my SM-N900T using Tapatalk
amazingbrz is offline   Reply With Quote
Old 10-08-2014, 03:38 AM   #2
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'd take it to America's Tires. They constantly patch tires. Looks like it would be fine. The damage is on the tread, not the sidewall.
Old 10-08-2014, 03:42 AM   #3
tyrantcf
Drives: '16 WRX, CBR1000RR
That one is very close to the shoulder of the tire is my concern. From that picture, I think its an easy cut and dry patch job. But some shops might hesitate because of it's proximity to the sidewall. My .02
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 10-08-2014, 03:57 AM   #4
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
I had a tire like that patched, constantly lose pressure so I just get an new tire
Speed2th is offline   Reply With Quote
Old 10-08-2014, 09:33 AM   #5
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I wouldn't drive on a tire punctured like that at auto x or lapping but it might be ok for daily use...
BRZZZZZZZZZZ is offline   Reply With Quote
Old 10-08-2014, 09:46 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
That's a big reason I decided to buy a track set. I feared having a puncture on the way to an event and being SOL.
Old 10-08-2014, 09:58 AM   #7
53Driver
T64-416Ax3=13,140shp
53Driver's Avatar
Drives: 2002 AP1 and 2015 F-150 EB (DD)
Sorry, but Federal regulations now state that tire shops can't repair any punctures that are within 2 inches of the sidewall. No, I can't quote the regulation for you but I've had to replace 3 tires on 2 vehicles in the last 4 months. The first time I took it to the dealership and when they told me that I thought they were trying to pull a fast one one me so I drove it across the street to the local Sam's Club. They told me the same thing. I then phoned a guy I went to high school with back in California who owns a tire shop and he told me the same thing. So 3 tires, 4 months. Not happy but in the end a tire shop will follow the laws less they face lawsuit and fines and also you have to consider your safety and those on the highways you will be driving with.
53Driver is offline   Reply With Quote
Old 10-08-2014, 12:39 PM   #8
EAGLE5
Dismember
EAGLE5's Avatar
53Driver, don't be a mark. There are no laws about 2". Total lies you've been fed.
http://www.rma.org/tire-safety/tire-repair/
Repairs are for the tread area only. You're within the tread area. You can see the line in the rubber. That screw looks to be less than 1/4" in diamter. Not big at all. Go to America's Tires. They'll probably fix it right, and possibly for free. Nitto even has guidelines about the tire's speed rating after repair. You'll be sad to know that your tires will likely only be good for 130mph.
Old 10-08-2014, 12:43 PM   #9
636
636's Avatar
Drives: '23 CWP BRZ
Just go to autozone and buy a plug, do it yourself. Takes no time at all.
I've plugged my car's tire twice, and my motorcycle like three times, and they all held up great.
...even at 170mph.
636 is offline   Reply With Quote
The Following 5 Users Say Thank You to 636 For This Useful Post:
Ammonia (10-08-2014), Basket Case (10-09-2014), Jrryjms07 (10-08-2014), SkAsphalt (10-08-2014), STV3 (10-08-2014)
Old 10-08-2014, 12:46 PM   #10
stonenewt
Drives: BMW 120d
Around here they'd have that off the rim to look at the inside and see what damage has been done before saying yay or nay. Another 15-20m further in and it would definitely be repairable.
stonenewt is offline   Reply With Quote
Old 10-08-2014, 01:48 PM   #11
amazingbrz
amazingbrz's Avatar
Thanks for the input guys
Here are some better pictures of it
I had to drive on it to get to work since it was still holding air for now.....but I'm worried about driving on it with that bolt sticking out like that ....
Size:  75.5 KBName:  uploadfromtaptalk1412790412771.jpg
Old 10-08-2014, 01:55 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
Driving around on it is bad. Get it looked at. Stone is right that it should be looked at from the inside, but that's what all legit shops would do anyway.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Dream20b (10-08-2014)
Old 10-08-2014, 02:03 PM   #13
Dream20b
Y u do dis?
that's a full on bolt...
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
STV3 (10-08-2014)
Old 10-08-2014, 02:32 PM   #14
stugray
Drives: 2013 GBS BRZ Limited
WHO's the Mark?
The very link that you post shows that the OPs puncture is OUTSIDE the "tread area" and in the "Shoulder".
From the very site you linked to:
And from Tire rack:
http://www.tirerack.com/tires/tirete...jsp?techid=187
"Repair of any punctures in the shoulder and sidewall areas is not permitted."
"This tire has been punctured through the shoulder area long enough ago for part of the nail head to have worn away. Since the puncture is outside the permitted repair area, this tire must be replaced."
AND the fact that the bolt in the OPs tire appears to be at least a 1/4", then it cannot be repaired "By industry guidelines".
"Guidelines allow the repair of punctures in a tire's tread area of up to 1/4" in diameter. Repair of larger tread punctures and of punctures to the tire's shoulder and sidewall areas are not recommended."
So based on the above, I would say that the tire repair place will NOT repair that puncture, especially if it is a speed rated tire AND the fact that the OP drove on it like that.
The Following 5 Users Say Thank You to stugray For This Useful Post:
53Driver (10-08-2014), 8R6 (10-09-2014), Ammonia (10-08-2014), JohnJuan (10-08-2014), wheelhaus (10-09-2014)
Dai Yoshihara's 2014 Falken Tire/Discount Tire Subaru BRZ FD Reveal SnapOv3st3r BRZ Photos, Videos, Wallpapers, Gallery Forum 62 04-15-2014 02:26 PM
Tire for 250 whp kaybee123 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 02-15-2014 09:04 PM
WTB: 1 OEM FRS/BRZ Tire RedFR-s Canada Classifieds 3 11-08-2013 11:43 AM
WTB One (1) OEM Tire Trojan_SC Wheels and Tires 2 05-07-2013 03:59 PM
What tire PSI are you using SEC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-30-2012 09:09 AM
