Old 10-06-2014, 02:07 PM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Are my Speigler brake lines defective?
I sent a message to @CSG Mike and tried the CSG phone number but since my car is in the air without brake lines I just going to see if anyone has these and if it is deffective or not.
The lines were not fitting properly into the brake line bracket and I looked closer and they seem to be mushroomed? Is this normal?
If I try to tight them only the rubber bit will seat in the bracket, the circle metal bit does not.
Please any input is appreciated.
Old 10-06-2014, 02:20 PM   #2
CSG David
CSG David's Avatar
Just called and sent a message. Anyways, the rubber bit will reduce the vibration and chaffing on the line. This is normal. Make sure you route the line properly so you have full range of motion without snagging.
Old 10-06-2014, 03:17 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Thanks for the reply.
So this is how it should look? this is finger tight, if I torque it it is not going to sit flush.
Last thing, what is the best way to get this excess pad material off so the pads fit in the calipers? I don't have a grinder maybe i have to buy one.
Old 10-06-2014, 05:22 PM   #4
Put sandpaper on a flat surface (such as the garage floor), and just slide the pad back and forth. The pad material itself can be tapered, so don't worry about getting it perfect.
The rubber should be ever so slightly mushroomed; it's supposed to cushion the line. Rubber is used in the same manner when mounting oil coolers
The bracket and line should be flush; they're both flat, but as long as the rubber is cushioning the line from the stock bracket, you're good to go.
Old 10-07-2014, 02:42 PM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
Thanks for setting me straight guys
Used 100 grit sandpaper and fixed the pads
Everything is installed and working great. Used less than 1 L of brake fluid even with replacing all 4 brake lines and bleeding twice. I'll get to test them at the end of the month at NJMP Thunderbolt, can't wait
Thanks again.
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 07:14 PM
Brake Lines for GT (not GTS) koevasi AUSTRALIA 7 05-26-2014 08:04 PM
Brake lines rev3la7ion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-14-2014 10:24 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
