Old 10-04-2014, 04:31 PM   #1
choi0706
Drives: t
throttle body coolant
anyone bypass this?
choi0706 is offline   Reply With Quote
Old 10-04-2014, 05:02 PM   #2
350matt
Drives: toyota mr2/ Toyota GT86
I'd agree that this is a good idea as unless you're in the Antarctic there's no need to heat the throttle body motor
350matt is offline   Reply With Quote
Old 10-04-2014, 05:45 PM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Whilst I agree with the sentiment the region just downwind of the butterfly valve experiences low pressure drops which can lead to icing even in temperatures above freezing temperature of the ambient air. Given that the throttle body is quite short I am suggesting the amout of heating this does to the ingoing air is quite small.
Old 10-04-2014, 06:54 PM   #4
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
I was going to post the same thing. Not many people believe this
Digitalanalog is offline   Reply With Quote
Old 10-05-2014, 01:22 AM   #5
Poodles
Drives: 2015 Series.Blue
Not going to make any more power and it's there to stop icing (which can happen at temps as high as 70F).
It depends on a lot of factors (humidity, pressure, etc).
Old 10-05-2014, 02:44 AM   #6
Captain Snooze
Drives: Red Herring
While I knew of the phenomena I didn't realise it could be as high as that.
Old 10-05-2014, 02:53 AM   #7
Digitalanalog
Isn't it called the venturi effect?
Old 10-05-2014, 06:49 AM   #8
FirestormFRS
Go ahead and by pass that shit. The multitudes of automotive engineers that design stuff like that have no clue wtf they're doing.
FirestormFRS is offline   Reply With Quote
Old 10-07-2014, 05:43 PM   #9
blown
Drives: ft86
http://delphi.com/pdf/techpapers/2008-01-0439.pdf
blown is offline   Reply With Quote
Old 10-17-2014, 07:42 PM   #10
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
so let me get this straight...
remove the bypass, and get ice in throttle body.
The more ice in the throttle body, the colder the air charge.
The cooler the air charge, the more power.
The more power, the less chance of being smoked by prius.
win.
Obviously jk
Old 10-17-2014, 10:21 PM   #11
kodyo
Drives: Scion FR-S
Sounds like Joules-Thomson effect to me.
kodyo is offline   Reply With Quote
Old 10-18-2014, 12:06 AM   #12
Then you stall out and crash.
Old 10-18-2014, 12:19 AM   #13
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
Venturi effect is more so the increase in a fluid flow' velocity due to a restriction/decrease in the cross sectional area of the flow.
00NissanNinja is offline   Reply With Quote
Old 10-18-2014, 12:26 AM   #14
^^^this
Cusco Throttle Body? track_warrior Engine, Exhaust, Transmission 66 06-28-2016 06:28 PM
FA20Club Throttle Body JDogg Engine, Exhaust, Transmission 22 12-01-2014 04:00 AM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
