Old 10-03-2014, 04:25 PM   #1
Double4Free
Ashes to ashes.
Double4Free's Avatar
Drives: Asphalt FR-S
Steel Rims with OEM lugs
Good idea? Bad idea?
I ask because the shop I just went to said I should buy new lugs for my steelies because the OEM ones don't tighten enough. Not sure if they're just trying to pad the bill or if they actually had my interests at heart.
Has anyone used the OEM lugs with steel rims on here?
It is in change that we find purpose.
Double4Free is offline   Reply With Quote
Old 10-03-2014, 04:58 PM   #2
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
No, they are correct.
The steel rim flange is much thinner than the hub on the aluminum wheels so the stock lugnuts will bottom out.
You will need longer lugnuts, 35mm ones should be fine.
Slick is offline   Reply With Quote
Old 10-03-2014, 05:05 PM   #3
Double4Free
Ashes to ashes.
Could you recommend some beater lug nuts that wont cost an arm and a leg? I hear open ended lug nuts (the ones I have currently for my winter set) are really bad for the lug studs and cause rust.
Old 10-03-2014, 07:15 PM   #4
Double4Free
Ashes to ashes.
http://www.pepboys.com/product/detai...eel_studs_nuts
would these work?
Old 10-03-2014, 08:17 PM   #5
tobin
tobin's Avatar
Drives: '13 BRZ
I reused my stock lug nuts on steel wheels and was totally fine last winter. I guess it might depend on the thickness of the steel like Slick said. YMMV.
tobin is offline   Reply With Quote
Old 10-03-2014, 09:32 PM   #6
vividracing
vividracing's Avatar
Its almost always best to run after market lugs with the proper lug seat when running an optional wheel.
vividracing is offline   Reply With Quote
Old 10-03-2014, 09:40 PM   #7
Double4Free
Ashes to ashes.
I just took a look at my winters and the rims are a bit thick.
Where could I go to have them tell me which lug for my winters would be good?
Old 10-03-2014, 09:50 PM   #8
Double4Free
Ashes to ashes.
Also sorry for all the questions. I'm very noob when it comes to wheels and tires.
Steel rims picture thread Trettiosjuan FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 59 04-04-2025 09:20 PM
Red lugs on Stock rims? gatorbushmen Cosmetic Modification (Interior/Exterior/Lighting) 9 04-23-2013 06:54 PM
SoCal Selling MUTEKI Lugs and Locking Lugs evilconcarne999 Wheels and Tires 0 03-18-2013 03:11 AM
FS: Gislaved NordFrost 5 (205/55/R16) winter tires on steel rims Burrcold Canada Classifieds 2 02-08-2013 07:59 PM
For sale stock rims and tires and lugs no tpms $ 500 OBO Gshoxx Wheels and Tires 10 01-04-2013 12:27 PM
