| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Ashes to ashes.
Drives: Asphalt FR-S
Steel Rims with OEM lugs
Good idea? Bad idea?
I ask because the shop I just went to said I should buy new lugs for my steelies because the OEM ones don't tighten enough. Not sure if they're just trying to pad the bill or if they actually had my interests at heart. Has anyone used the OEM lugs with steel rims on here?
It is in change that we find purpose.
#2 | |
Drives: FR-S Firestorm 6MT
The steel rim flange is much thinner than the hub on the aluminum wheels so the stock lugnuts will bottom out. You will need longer lugnuts, 35mm ones should be fine. |
#3 |
Ashes to ashes.
Could you recommend some beater lug nuts that wont cost an arm and a leg? I hear open ended lug nuts (the ones I have currently for my winter set) are really bad for the lug studs and cause rust.
#4 |
Ashes to ashes.
http://www.pepboys.com/product/detai...eel_studs_nuts
http://www.pepboys.com/product/detai...eel_studs_nuts http://www.pepboys.com/product/detai...eel_studs_nuts would these work?
#5 |
Drives: '13 BRZ
I reused my stock lug nuts on steel wheels and was totally fine last winter. I guess it might depend on the thickness of the steel like Slick said. YMMV.
#6 |
Its almost always best to run after market lugs with the proper lug seat when running an optional wheel.
#7 | |
Ashes to ashes.
Where could I go to have them tell me which lug for my winters would be good?
#8 |
Ashes to ashes.
Also sorry for all the questions. I'm very noob when it comes to wheels and tires.
| Steel rims picture thread | Trettiosjuan | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 59 | 04-04-2025 08:20 PM |
| Red lugs on Stock rims? | gatorbushmen | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 04-23-2013 05:54 PM |
| SoCal Selling MUTEKI Lugs and Locking Lugs | evilconcarne999 | Wheels and Tires | 0 | 03-18-2013 02:11 AM |
| FS: Gislaved NordFrost 5 (205/55/R16) winter tires on steel rims | Burrcold | Canada Classifieds | 2 | 02-08-2013 06:59 PM |
| For sale stock rims and tires and lugs no tpms $ 500 OBO | Gshoxx | Wheels and Tires | 10 | 01-04-2013 11:27 AM |
