Old 10-02-2014, 09:59 AM   #1
sam69
Drives: GT 86
Best Water Meth Kit For FI For The Twins ??
As the title says trying to figure out which is the best kit for our cars .
I have a Sprintex Sc on my 86 and do not have access to e85 and have been looking at water meth kits and like the look of the ptuning unit the most so far as it is made for the twins.
I know that it's only for LHD atm but hopefully that will change in the not to distant future if the RHD battery tray is a mirror image of the LHD tray.
http://www.ptuning.com/subdir/search...=PTP-ENG-90055
Others I have looked at are .. http://www.coolingmist.com/pagedispl...re_key=systemx
http://www.aemelectronics.com/produc...soline-engines
and ... http://www.alcohol-injection.com/en/
Any other suggestions based on experience would be appreciated and has any one got a ptuning kit fitted to their car that can give first hand feedback ?
sam69 is offline   Reply With Quote
Old 10-02-2014, 11:44 AM   #2
mike the snake
I went a different route and tuned my car with the standalone Hydra ECU from Element Tuning, and used the Hydramist meth system they sell that is integrated with the Hydra.
I'm loving everything about my car and tune right now so far.
Old 10-02-2014, 08:23 PM   #3
sam69
Drives: GT 86
Thanks for that have had a look .. http://www.elementtuning.com/Hydrami..._hydramist.htm
Was wondering if you have any pics of where you mounted the tank, pump ,flow gauge etc.
Being very new to all this would I be able to have the fail safe programmed into the ecu with an Ecutek tune or do I need something additional
to make it all work
Old 10-02-2014, 08:29 PM   #4
mike the snake
I believe there are a number of safety features from both the meth system and whatever system you're tuning with. My Hydra pulls a bunch of timing if low/no meth is detected. Not sure about Ecutec.
Another outfit here, (Ptuning or P&L, not sure) offers a basically plug and play meth system with Ecutek.
Old 10-03-2014, 01:04 AM   #5
protpibe
protpibe's Avatar
I was in the same boat as you and ended up ordering the PTuning kit. I don't have any impressions on it since they haven't been formally released yet. I was told that mine ships tomorrow so I'll check back here when I get it
Old 10-04-2014, 06:35 PM   #6
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
+1 on the kit for RHD cars with no access on E85 and ridiculously expensive race fuel that cost more than $100 per gallon
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 10-05-2014, 10:55 AM   #7
mrk1
Drives: Sterling BRZ Ltd
Aquamist is a very nice kit. I am putting together a kit on my car and am very impressed with there company quality.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-05-2014, 03:22 PM   #8
mike the snake
My Hydramist system IS an Aquamist, just controlled by the Hydra standalone instead of the Aquamist controller.
It has functioned perfectly.
Aquamist, controlled by Ecutek, I think would be just as good (meth-wise).
Old 10-05-2014, 11:20 PM   #9
sam69
Drives: GT 86
Have sent pics of RHD battery tray to ptuning so will see if it's possible to do a mirror image.
Old 10-06-2014, 06:04 PM   #10
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Thanks @sam69 for the pics of the RHD battery location. We've already started working on the mirror image of some of the components. Not all the components will be mirrored since the bottle with the level sensor will be the same bottle.
The pump mounting bracket was already designed to be mounted on either side of the vehicle underneath the front bumper beam mounting holes, so that's a few less components that will need to be designed.
Here's a picture of the WMI system (LHD on the left, and RHD on the right). Our only concern is whether or not toyoto made a mirror all the moutning hole locations for the stock battery--since our WMI tray uses all 4 mounting holes used by the oem battery.
It's going to take us about 3-4 weeks to get the first RHD test peaces built for fitment verification. But before we put anything into production, we would like to gauge real interest in the RHD version of our Pnp WaterMeth injection system.
MrC
Mrc@ptuning is offline   Reply With Quote
Old 10-06-2014, 09:32 PM   #11
mike the snake
If you're stuck with California crap 91 gas, especially if you are FI, the ONLY way you're going to see bigger power is with lower compression, or a meth system like the Aquamist.
I'm loving my Aquamist/Hydramist system. It has worked flawlessly, and has been good for a LOT of extra power.
Old 10-07-2014, 06:53 AM   #12
sam69
Drives: GT 86
Hey Mike would you be able to post pics of where you've mounted your water / meth container, pump etc in your car.
Would love to see how you have set yours up .
Old 10-07-2014, 08:03 PM   #13
Turbowned
Turbowned's Avatar
Getting ready to fit a Snow Performance W/M kit on my Vortech SC'd BRZ soon; I'll let you all know how it works out!
Old 10-08-2014, 10:49 AM   #14
mrk1
Here is how I mounted mine, Dual 3 quart tanks. control gauge is on the dash, ecu is in the glove box.
The Build Thread
NA water meth injection? Ingen Engine, Exhaust, Transmission 26 06-03-2014 05:08 PM
what meth kit are you using Frs300 Forced Induction 30 04-29-2013 02:18 PM
AEM WATER METH METHANOL INJECTION KIT JPxM0Dz Engine, Exhaust, Transmission 10 04-13-2013 11:03 PM
Meth/Water Injection question showbe Engine, Exhaust, Transmission 9 10-18-2012 07:25 PM
Nitrous Oxide/Meth injection JDLM Engine, Exhaust, Transmission 6 12-17-2011 04:23 AM
