Old 11-27-2012, 11:10 PM   #1
Ingen
Drives: Ultramarine FR-S 6MT
NA water meth injection?
Random question time, and I am pretty tired and on my iPad so... It might not make a lot of sense.
Anyway. I have been a bit jealous of folks with tunes on e85 getting extra power. I want some too, but I don't have e85 readily available.
Would it be possible to add a water meth injection kit to avoid detonation with an aggressive tune on 93 octane? I have heard of it in turbo applications but never in a naturally aspirated car.
People who know more than me, please help!
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 11-27-2012, 11:16 PM   #2
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
It's being researched to see if it will make any power for the same reason you stated, not everybody can get E85.
I don't know if it's been installed yet or tuned but the plan is out there. @FA20Club.com
JoeBoxer is offline   Reply With Quote
Old 11-27-2012, 11:24 PM   #3
FA20Club.com
Drives: 2013 White Out FR-S
The kit is here just have to find some time to get it installed on a stock car for testing....?
FA20Club.com is offline   Reply With Quote
Old 11-27-2012, 11:35 PM   #4
chutrain
chutrain's Avatar
Drives: WRB BRZ
I would be against it. It's not as safe in a way as E85. Why people are shifting away and going the E85 route. If for any rain the pump goes, there goes the motor. Not sure it would be as beneficial going this route in NA as a turbo.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 11-27-2012, 11:42 PM   #5
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Running a straight Methanol no water would be best. Water is used to cool the charge. Since there is no turbo present it doesn't really do much. Meth on the other hand give more fuel and will keep detonation at bay so I could see some benefits to it. Lean out the GAS add Meth make more POWER.
jdzumwalt is offline   Reply With Quote
Old 11-28-2012, 03:39 AM   #6
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
It's possible to program in failsafes for cases like the pump dying or the water lever drops too low... such as map switching.
uspspro is offline   Reply With Quote
Old 11-28-2012, 04:06 AM   #7
serialk11r
Drives: '06 AM V8V Coupe
Or you know, just pressing on the accelerator a little less.
Old 11-28-2012, 04:51 AM   #8
invisage
Drives: Thunder Silver 86 GTS
Don't tease like that
invisage is offline   Reply With Quote
Old 11-28-2012, 05:15 AM   #9
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
Theres only so much you can advance the timing in the window... not sure methanol injection would be worth it, it would increase the octane rating, but not sure youd really be able to do much with it. If your gonna spray methanol, you might as well spray nitrous, safer and bigger power numbers.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 11-28-2012, 06:02 AM   #10
serialk11r
Spraying nitrous sounds a lot more dangerous than spraying methanol to me...methanol is just fuel, and it's "better" for the engine than gasoline since it cools the air more. Nitrous is adding oxidizer, and thus increasing burn temperature significantly. Of course, this gives you a ton more power as well.
Old 11-28-2012, 06:19 AM   #11
Calum
That Guy
Drives: 2013 asphalt FRS MT
91 octane oxygenated American beer is what we get for gas here. Any help with raising the effective octane would be great.
Old 11-28-2012, 07:00 AM   #12
Grishbok
Grishbok's Avatar
Injecting nitrous is much safer. I explained in another thread, but will do so again, that nitrous is n2O, meaning two nitrogen and an oxygen atom. During the combustion process the nitrogen is seperated form the oxygen, leaving free floating oxygen in the combustion chamber, oxygen is air, meaning your doing nothing more than putting more air into the combustion chamber, the free floating nitrogen acts as a buffer to prevent detonation and compressed nitrous sprays at a temperature of +- -127*F
The increased power comes from the combustion of the pure unbonded oxygen. Obviously trying to shove 500hp shot is not safe, but a 50shot would be perfectly fine. even a 25 shot or a 20 shot if they made nozzels that small would be able to produce more of a hp/tq # than methanol.
The Following User Says Thank You to Grishbok For This Useful Post:
ML (11-28-2012)
Old 11-28-2012, 06:54 PM   #13
invisage
Difference is nos is a limited use application while a meth/water kit is continously running. There are other great benefits to meth/water kits too like that it helps with carbon build up in parts or the engine like the combustion chamber. They work best in high compression engines and because they lower the air temp coming in they are even better when combined with FI. But we will see soon wont we FA20Club.com
Old 11-29-2012, 05:39 PM   #14
S1000rr
Drives: Silver
100% meth is not very safe. Water also helps dilute the meth in order to keep things safe under the hood. As you said though water is used for cooling which actually sweats on the cylinder walls. A 60-40 mix would probably be good, but in our case E85 would probably be a lot easier to accomplish the power gains.
S1000rr is offline   Reply With Quote
Alcohol Injection Ess Vee Forced Induction 34 01-28-2016 07:43 PM
Meth/Water Injection question showbe Engine, Exhaust, Transmission 9 10-18-2012 07:25 PM
ever seen fuel injection like this? carbonBLUE Other Vehicles & General Automotive Discussions 1 10-17-2012 02:17 AM
Gasoline Direct Injection... DoogenBurns Engine, Exhaust, Transmission 5 05-21-2012 02:05 PM
Nitrous Oxide/Meth injection JDLM Engine, Exhaust, Transmission 6 12-17-2011 04:23 AM
