Old 09-30-2014, 05:14 PM   #1
JoonPrime
Drives: 2015 Limited series all white brz
is mixing different types of gas bad for t fillhe car??
Hey guys just a quick question.
ive downed about 4000 miles on my car so far and read higher octane *could* help with my cricket noise a bit, as well as being betterfor the car and such.
ive recently gone from the east coast 92 wawa e10 gas to a 93shell. however much to my dismay, my mileage actually went down
i wasnt driving rougher, if anything i drove as careful as possible during my first fill in for shell.
im now thinking of trying out sunoco (shell, wawa, and sunoco are pretty abundant in my area of delaware/pa) should i do anything before fillin her up? is there such a thing as flushing out the car completely of the fluids and starting up fresh?? id like to switch my engine oils and trasmission fluids to motul eventually so i thought id ask ahead of time!
also, if anyones a local... wawa vs sunoco vs shell, which do you use??
JoonPrime is offline   Reply With Quote
Old 09-30-2014, 06:10 PM   #2
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
For mpg comparison purposes, you MUST be driving with the same driving style, and almost the same, if not identical, mix of highway/street usage. Otherwise, the mpg comparison is useless because you have too many variables.
aegisdrgn is offline   Reply With Quote
Old 09-30-2014, 06:17 PM   #3
JoonPrime
precisely ! my driving style was id say about 75% more careful then normal,( never shifted above 4k rev) and i was averaging 30.5 on average before on 92 wawa. then i dropped to 28mpg on my first fillup on shell while i drove in the same conditions, but safer so im a bit appalled....
Old 09-30-2014, 09:16 PM   #4
aegisdrgn
aegisdrgn's Avatar
Hmm, you might want to keep on the Shell for a couple more tanks, because a sample size of 1 is not enough. Instead of trying to drive carefully, just try driving like before. Change one thing at a time, so you can analyze the change effectively.
Old 10-01-2014, 12:03 AM   #5
humfrz
I'd just use up/drain out the old gas/fluids and fill with the new gas/fluids.
humfrz
Old 10-01-2014, 06:08 PM   #6
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
You should try a few tanks before making a clear decision.
There's so many variables...
Was the batch of gas you got not quite the octane it said? Was it hotter/colder out? Was the car idling longer? did you put the new type of gas in when there was still a large volume of fuel left?
I use Shell 91 (highest octane I can get) and I don't put anything else in unless I absolutely need to.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 10-10-2014, 03:45 PM   #7
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I would repaint
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 10-10-2014, 03:51 PM   #8
Fastbrz
Drives: Wrb brz
You can't even compare Wawa fuel because they get their fuel from the cheapest place possible. It's never consistent. Also, Wawa does not add any additives to the fuel. The only reason Wawa has fuel is to bring customers into the stores. They don't make a dime on fuel. Stay with a quality fuel like v power from shell.
Fastbrz is offline   Reply With Quote
Old 11-01-2014, 11:05 PM   #9
Chanpion
Drives: 13 FRS Satin
Recommended is 94, some places don't sell that so don't use anything under 91 or "Premium". It's okay to mix. Second, there's a warning in the owner's manual to not use any gas with a % of ethanol. Can't remember the number but it says try to stay away from ethanol gas.
Chanpion is offline   Reply With Quote
Old 11-02-2014, 09:31 AM   #10
Hoahao
Drives: 2014 Monogram Hot Lava
I buy at the Shell at the intersection of Thompson Station and Paper Mill Rd across from the Bank of America. I get the 93 and have not noticed any difference but don't have many miles on the car yet.
They don't have the very best prices but it still beats Pa gas stations, and they have a lot of traffic in and out so thetanks get refilled often.
Hoahao is offline   Reply With Quote
Old 12-02-2014, 10:11 AM   #11
babylobster
babylobster's Avatar
Drives: Firestorm Red 2013 Scion FR-S 6Spd
I've been trying to use only Sunoco 91 or 93 but is it true that 91 is "good enough" and getting 93 is wasting money? Also, if you're mixing 91 (or any grade) from different companies (i.e. Mobil, Sunoco, Shell, etc) is that bad? Sorry if these are stupid questions!
babylobster is offline   Reply With Quote
Old 12-02-2014, 01:19 PM   #12
JB86'd
JB86'd's Avatar
Drives: JAWS
91 is "good enough" but 93 will get you more power, better mpg, and safer with less knock. If you have it available it's worth the extra money. Mixing different company's gas is not bad.
Old 12-02-2014, 02:51 PM   #13
LzT AngeL
Drives: 2013 Scion FR-S Firestorm
In Florida it goes from 87, 89, to 93 so I just use 93 becuase they do not have the 91 octane that it recommends. When I was low on cash I did mix half 89 and half 93 and it should be good.
LzT AngeL is offline   Reply With Quote
Old 12-02-2014, 09:38 PM   #14
JB86'd
JB86'd's Avatar
Drives: JAWS
The manual reccommends 93 octane...stop
The Following User Says Thank You to JB86'd For This Useful Post:
kch (12-03-2014)
Mixing Coolants MrTranxD Issues | Warranty | Recalls / TSB 14 12-03-2014 08:48 PM
Oil Types and Makes? subieshanerz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-23-2014 08:24 PM
Mixing Oil Brands? 10Tim Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-02-2014 11:36 AM
Mixing Transmission Fluids? l0aded Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 06-27-2013 01:45 PM
What is it that makes people mixing up the GT86 with a Supra Killerbee Scion FR-S / Toyota 86 GT86 General Forum 31 12-20-2012 02:24 PM
